What is the Best Method to Find the Peak Point of a Quadratic Bezier Curve?
  • Context: Undergrad
  • Thread starter Thread starter temp
    Curve Peak Point
The discussion revolves around methods to find the peak point of a quadratic Bezier curve, focusing on various approaches and interpretations of what constitutes the "peak" point. Participants explore mathematical techniques and reasoning related to the curve's properties, including distance calculations and derivatives.
  • One participant suggests calculating the maximum distance between the start point, any point on the curve, and the end point, but notes this method is computationally intensive.
  • Another participant proposes solving for where the derivative of y equals zero (y' = 0) to find maximum or minimum points on the curve, using parametric equations.
  • A different participant clarifies that they are looking for the maximum point on the curve, not just maximum y or x values.
  • Some participants discuss the slope at the peak point, with one asserting it is -1, while another argues it is zero depending on the specific problem context.
  • One participant mentions that finding the maximum distance from a reference point to the curve involves solving a cubic equation derived from the distance formula.
  • There is a disagreement about the interpretation of the peak point, with some thinking it refers to maximum y while others consider it as the point farthest from the origin along the curve.
Participants express differing interpretations of what the "peak" point means, leading to multiple competing views on the appropriate methods to find it. The discussion remains unresolved regarding the precise definition and approach to identifying the peak point.
Participants highlight that the problem's specifics can affect the interpretation of the peak point, including the slope conditions and the nature of the cubic equation derived from the distance calculations.
temp
hello
i want to find the peak point of a quadratic bezier curve.
one approach is finding all distance between "start point","any point on curve","end point"
and then choosing then maximum distance between them.
but this approach get much time when implementing on computer
is there any other approach?
Mathematics news on Phys.org
I think all you have to do is solve y' = 0, just like you do in a non-parametric equation. Here's the logic. A max or min will occur where dy/dx = 0. In a parametric equation x = f(t) and y = g(t), dy/dx = (dy/dt)(dt/dx) = y'/x'. If you find where y' = 0, that's also where dy/dx = 0, unless x' happens to be zero or infinity at the same location.
Since you are dealing with a quadratic bezier:
[tex]x = a_xt^2 + b_xt + c_x[/tex]
[tex]y = a_yt^2 + b_yt + c_y[/tex]
then a max/min will occur at:
[tex]t = \frac{-0.5b_y}{a_y} = \frac{P_{y0} - P_{y1}}{P_{y0} -2P_{y1} + P_{y2}}[/tex]
thanx
but it gives me maximum-y point
i also can use such formula to calculate maximum-x point
but what i need is maximum point on curve (see below picture)
Think a bit. Try drawing lines x + y = c for different values of c.
do you read my first post carefully?
do your mean is such mine?
I didn't clearly understand what you are saying :(
But I was trying to tell you that at max point the slope of curve is -1.
Hope this helps.
I don't think temp made it very clear what he was asking for- in particular he never said what he meant by "peak" point. I too thought he meant "maximum y" but then he started talking about finding the maximum distance along the curve from some starting point. I can't connect that with any reasonable concept of "peak".
Oh, and I'm sure you meant to say, "at max point the slope of curve is 0", not 1!
Actually, by max point I meant what temp was referring to as max point (the "?" in the figure). This max point is the point farthest from origin, lying on the curve, I suppose.
that's true
i marked "?" in my attached image to tell you what i need.
So did you get my idea (at "?" slope is -1)
Yeah, I thought peak meant maximum y. If it really means the distance to the curve from some reference point (x0, y0), then it seems to me the problem boils down to solving a cubic equation.
[tex]d^2 = (x - x_0)^2 + (y - y_0)^2[/tex]
Since x and y are quadratic in t, d2 is a 4th order equation in t. Taking the derivative and setting equal to zero involves solving a cubic equation, which can be done analytically or numerically. Or, am I not understanding something?
You are absolutely correct. A bit of manipulation will end you up the same thing I was telling (slope = -1).
ok
but my mean is not finding slope at "?"
My Mean Is Finding Position Of "?" Point!
there are other sample:
http://www.hostdump.com/uploads/cb2d22775c.jpg
I disagree, unless I'm totally not understanding what is going on. Look at this simple example: http://www.hostdump.com/uploads/212436219e.jpg
The maximum distance from (x0, y0) to the curve is a vertical line - the slope of the curve is zero,
not -1. It is problem dependent. Certainly there are specific problems where it is true, but not in general.
temp,
What said before I believe is correct. Write the expression for distance from the reference point to the curve, take the derivative with respect to t, set = zero, and solve (the resulting cubic equation) for t. In the case of the specific posted example, t = 0.5, which means x = 0, y = -1.
[tex]d^2 = (x-x_0)^2 + (y-y_0)^2[/tex]
[tex]d(d^2)/dt = 0 = 2(x-x_0)x'+ 2(y-y_0)y' = (x-x_0)x'+ (y-y_0)y'[/tex]
[tex]0 = (a_xt^2+ b_xt + c_x - x_0)(2a_xt + b_x) + (a_yt^2+ b_yt + c_y - y_0)(2a_yt + by)[/tex]
[tex]0=2t^3(a_x^2+a_y^2)+3t^2(a_xb_x+a_yb_y)+t(2a_xc_x-2a_xx_0+b_x^2+2a_yc_y-2a_yy_0+b_y^2)+b_xc_x-b_xx_0+b_yc_y-b_yy_0[/tex]
For the specific problem posted, the cubic to be solved is:
[tex]0 = 32t^3 - 48t^2 + 12t + 2[/tex]
The 3 solutions are:
[tex]t = (-0.112, 0.5, 1.112)[/tex]
There is only 1 value of t within the desired range of t=0,1 and that's t = 0.5, which is the point of maximum distance from (x0, y0). The other 2 values of t represent minimum distance.
Like I said before, the key to this problem is solving a cubic equation - that can be done analytically or numerically. Here is a more complicated example: http://www.hostdump.com/uploads/2c1856190f.jpg
21K
  • · Replies 39 ·
  • · Replies 16 ·
  • · Replies 24 ·
11K
