How Fast is a Particle Moving from the Origin at (3,-4)?
  • Thread starter Thread starter kuahji
    Particle Speed
This discussion revolves around a related rates problem involving a particle's movement in the xy-plane. The original poster seeks to determine how fast the particle is moving away from the origin as it passes through the point (3,-4), given the rates of change of its coordinates.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the Pythagorean theorem and implicit differentiation to find the rate of change of distance from the origin. They express confusion regarding the application of values from the problem into their derived equation.
  • Some participants question the correctness of the book's solution and the interpretation of the negative coordinate value in the context of distance.
  • Others suggest considering the magnitude of the velocity vector as a potential aspect of the problem, noting that the specific point may not be essential to the final calculation.
The discussion is ongoing, with participants exploring different interpretations of the problem and questioning the assumptions made in the original poster's approach. There is no explicit consensus on the correct method or interpretation, but some guidance regarding the importance of negative values and the concept of magnitude has been offered.
Participants note potential confusion stemming from the book's solution and the implications of using negative coordinates in the context of distance. The clarity of the problem's final question is also under scrutiny.
kuahji
This is a related rates problem
The coordinates of a particle moving in the metric xy-plane are differentiable functions of time t with dx/dt = 10m/sec & dy/dt = 5m/sec. How fast is the particle moving away from the origin as it passes through the point (3,-4).
First used the Pythagorean theorem & found D (distance) from the origin, which was 5. Then I implicitly differentiated the problem d^2=x^2+y^2
D dD/dt = x dx/dt + y dy/dt (divided out all the 2s). Then I plugged in the rates of change as outlined in the problem.
D dD/dt = 10x + 5y.
But at this step I must be misunderstanding something. I tried to plug (3,-4) in for x & y, & 5 in for D. However, according to the book that's incorrect. So what am I misunderstanding? The book shows 5 dD/dt = (5)(10)+(12)(5) but where are the second five in the equation & 12 coming from?
I don't know, because I agree with your solution. The 'book' isn't always right.
Ok, thank you for taking a look at the problem.
So it would probably look
5 dD/dt = (10)(3)+(-4)(5)
Then just solve? Or because it is distance, would I have to use positive 4 instead of negative? I'm thinking I'd have to use positive 4, but not so sure since I'm just learning all of this.
No, the negative is correct. In a related rates problem, negatives are very important. If dD/dt wound up negative, the distance would be decreasing
The only thing I can think of is that your book may want the magnitude of the particle's velocity. dx/dt is the horizontal component and dy/dt is the vertical component. The vector sum will give you a single velocity vector, and the magnitude is the speed. In this case, the point (3,-4) is just extra information and the last part of the question isn't very clear
