Relevistic energy problem : part 2
  • Thread starter Thread starter Benzoate
    Energy
The discussion focuses on the relativistic energy problem involving fully ionized gold (Au) nuclei colliding at 200 GeV per nucleon in the Relativistic Heavy Ion Collider at Brookhaven. The calculated speed of each Au nucleus before collision is approximately 0.999999999717c. The momentum is derived using the formula p=gamma*m*u, resulting in 4.09e-13 kg*m/s, while the energy calculated is 1.226e-4 joules. For the observer in the rest frame of the other Au nucleus, Lorentz transformations are applied to determine the energy and momentum, with the need to consider the relativistic velocity addition formula for accurate results.
  • Understanding of Lorentz transformation equations
  • Familiarity with relativistic momentum and energy calculations
  • Knowledge of gamma factor in relativistic physics
  • Basic principles of particle collisions in high-energy physics
  • Study the relativistic velocity addition formula
  • Explore detailed applications of Lorentz transformations in particle physics
  • Learn about the implications of relativistic effects on momentum and energy
  • Investigate the operational principles of the Relativistic Heavy Ion Collider (RHIC)
Students and researchers in physics, particularly those focusing on high-energy particle collisions, relativistic mechanics, and nuclear physics.
Benzoate
relavtivistic Heavy Ion collider at brookhaven is colliding fully ionized gold(Au) nuclei accelerated to an energy of 200 GeV per nucleon. each Au nucleus contains 197 nucleons . a) What is the speed of each Au nucleus just before collision b)What is the momentum of each at that instant? c) What energy and momentum would be measured for one of the Au nuclei by an observer in the rest system of the other Au nucleus
Possible equations: For Lorentz transformation equations, E=gamma*mc^2 ;p(x)=gamma*m*u(x) , u(x) being the velocity of the Au nucleon in the x dirrection.
I don't have trouble with part a, I'm only having trouble with parts b and c. I calculated the velocity to be , u= .999999999717c. and that's the correct velocity according to the back of my textbook. If you want to see how I calculated the velocity, go see my other posts titled relavistic energy problem In part b), since the value of u is extremely closed to the speed of light , I would used p=gamma*m*u. Therefore, p(x)=4152.27*(3.28e-25 kg)*(.99999999717*c)=4.09e-13 kg *m/s
E=gamma*mc^2= 4152.27*(3.28e-25 kg)*(.99999999717*c)^2 = 1.226e-4 joules
For part c) , I will have to used the Lorentz transformations for energy and momentum . I assumed the directions of y and z are zero, I think I'm supposed to find p'(x) and p'(x)= gamma*(p(x-vE/c^2) = 4152.27*(4.09e-13 kg*m/s-v(1.226e-4 joules))/c^2) and E'(x)=gamma*(E-v*p(x))= 4152.27*(1.226-4 Joules-v(4.09e-13 kg*m/s). I'm having trouble finding v. On second thought, wouldn't v=0 since the observer is in the rest system ?
I replied to your other post. These appear to be correct, but I think the velocity is somewhat less (as these things go) than you found.
I think you will want to use the relativistic velocity addition formula to find the velocity of one nucleus as seen in the rest frame of the other. Keep in mind that, since we are setting up a collision, the velocities of the two nuclei will be in *opposite* directions.
