A ball is thrown above th house
  • Thread starter Thread starter AvrGang
    Ball
The problem involves projectile motion, specifically the scenario of throwing a ball to clear a house's roof while maintaining a specific height. The original poster seeks assistance with determining the minimum speed required for the ball to clear the roof and the angle of the throw.
  • The original poster attempts to calculate the height difference needed for the ball to clear the roof and expresses difficulty in finding the necessary velocity. Other participants encourage sharing work to facilitate discussion and suggest using equations of motion for projectile analysis.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been provided regarding the use of equations of motion, but no consensus or resolution has been reached yet.
Participants are working under the constraints of a homework assignment, with the original poster specifically requesting hints rather than complete solutions. There is mention of using a graph from a textbook, which may influence the understanding of the problem.
AvrGang
Here is a question that I spent 1 hour trying to find a solution but I din't come up with any solution, so please give me any hint you know to solve this problem.
The question is:
You're 6.0 m from one wall of a house. You want to toss a ball to your friend who is 6.0 m from the opposite wall. The throw and catch each occur 1.0 m above the ground.
A.What minimum speed will allow the ball to clear the roof?
B.At what angle should you toss the ball?
Help me with the first part only, I can find the second part by myself.
I found the height from where the ball is caught(1.0m above the ground) to the highest point of the roof where the ball clear the roof. The height is 3 m
but Ididn't find an equation to find the velocity.
I'm online for any discussion
attempt attempt? show your so called stupid attempt, nobody is going to laugh at you, but we'd respect you for showing your work :)
i'm working on it right now, but someone who is better at physics might help you if you show some work
ok here is my attempt:
Show us the equation(s) you used to find the height.
i found it using the graph in my book
I'll try to post the graph
AvrGang said:
i found it using the graph in my book. I'll try to post the graph
No need. Isn't the idea to use appropriate equations of motion (in this case for a projectile) to solve the problem? Or, are you suppose to just analyze the graph, which I presume is a graph of distance vs time? Remember the definition of velocity?
  • · Replies 31 ·
