Parallel plate capacitor (voltage and charge relative to distance)
The discussion centers on the behavior of parallel plate capacitors (PP capacitors) when the plates are separated without a battery connected. It is established that the potential (V) increases as the distance (d) between the plates increases, despite the electric field (E) decreasing. The relationship is clarified by noting that while E decreases with distance, the work done to separate the plates increases the potential energy, leading to an increase in potential. The confusion arose from using unrealistic values for 'd', as the electric field remains constant when the separation is small relative to the plate dimensions.
  • Understanding of electric fields and potential difference
  • Familiarity with the concept of work done in electric fields
  • Knowledge of parallel plate capacitor theory
  • Basic algebra and calculus for analyzing relationships between variables
  • Study the derivation of the electric field for parallel plate capacitors
  • Explore the concept of capacitance and its dependence on plate separation
  • Learn about the energy stored in capacitors and how it relates to voltage and charge
  • Investigate the effects of varying plate dimensions on electric field strength
Students of physics, electrical engineers, and anyone interested in understanding the principles of capacitors and electric fields.
swarm
Hi all.
I'm struggling to understand something about PP capacitors. Let's say there is no battery connected to a PP capacitor.
Why does the potential (V) INCREASE when the plates are moved farther apart?
- we know that: dv = -Ed (in a constant E)
however as d increases, E decreases with the inverse square of d, falling off exponetially while d falls of linearly, so since E is getting smaller faster than d is getting larger, souldn't dv decrease as d increases?
- From a non-math perspective I understand it, work must be done to pull the plates apart, thus potential energy is increased, so dv would increase. My math just doesn't agree though.
Can someone point out my error? Many thanks in advance, this has been driving me nuts for a couple days now!
As long as the separation distance remains small with respect to the dimensions of the plates, the electric field remains constant. It does not drop off exponentially or as an inverse square with distance (as would happen with a point charge).
Thanks Doc Al, I think my problem was that I was using unrealistically high values for 'd' (1 meter or more), it makes sense now.
  • · Replies 16 ·
  • · Replies 33 ·
20K
  • · Replies 32 ·
