Algebra 2 Problems: Problem 2, 4, 14, 22 & 23
  • Thread starter Thread starter mustang
    Algebra Algebra 2
The discussion revolves around various Algebra 2 problems, including quadratic equations, solving square roots, and cubic polynomials. Participants are exploring specific problems related to vertex coordinates, discriminants, and polynomial roots.
  • Mixed
  • Participants discuss methods for finding the vertex of a quadratic and the discriminant of a quadratic equation. There are attempts to solve square root equations and to identify coefficients for a cubic polynomial given certain roots. Questions arise regarding the correctness of their approaches and the implications of complex roots.
Some participants have shared their attempts at solving the problems, while others have provided guidance on methods to approach the equations. There is an ongoing exploration of the relationships between roots and coefficients in polynomial equations, but no consensus has been reached on specific solutions.
Participants are working within the constraints of homework assignments, which may limit the information they can share or the methods they can use. There are indications of confusion regarding the application of certain algebraic principles, particularly in relation to complex numbers and polynomial factorization.
mustang
Consider the equation y=a(x-r1)(x+r2) for problem 2 & 4.
Problem 2. State the coordinates of the vertex.
Problem 4. State the value of the discruminant.
Problem 14. Solve: sqrt(x-4) + 10 = sqrt(x+4)
Problem 22.
Find integers b and c such that the equation x^3+bx^2+cx-10=0 has -2+i as a root.
Problem 23. If P(x) is a cibic polynomial such that P(-3)=P(-1)=P(2)=0 and P(0)=6, find P(x).
What progress have you made on the problems so far? Can you show us what you've tried?
cookiemonster
Problem 18.
3(2)^2+k(2)-8 ----I inserted the value of x equaling 2.
36+k(2)-8
28+k^2
k^2=-28
k=sqrt(-28)
k=2isqrt(7)
For the rectangle problem I believe that the problem is in the ax^2+bx+c=0.
This is Algebra 2 homework.
Regarding Problem 18??
Sorry it was to be referred to another question I had in a different thread.
Problem 22.
(2) Multiply a(x-r1)(x+r2) out and complete the square to find the vertex.
(4) You got a quadratic when you multiplied in (2) so just use the formula for the discriminant from the quadratic formula.
(14) Square both sides to get rid of (one of) the square roots. If you still have a square root left, square again!
(22) Assuming that b and c are supposed to be real numbers, then for the polynomial equation to have -2+i as a root, it must also have -2-i as a root. Now you know a and b in x^3+bx^2+cx-10= (x-a)(x-b)(x-c). Choose c so that -abc= -10.
(23) Just as the easiest way to solve a polynomial equation is to factor the polynomial, so a cubic with roots a, b, c can be written as (x-a)(x-b)(x-c).
For problems 14 and 22.
Problem 14.
This is what i have done:
(sqrt[x-4]+10)^2=(x+4)^2
x-4+20sqrt(x-4)+100=x+4
20sqrt(x-4)=92
400(x-4) = 8,464 --I squared both sides.
400x-1600=8464
400x=10,064
x=25.16
Is this right??
Problem 22.
This is what I have done:
Would i input the values -2+i and -2-i for a and b. TO find the value for c?
24K
