Solving motion of undamped harmonic oscillator
The motion of an undamped harmonic oscillator under a non-constant applied force F = F0 + kT can be described using the equation of motion x'' + ω0^2x = F/m. By substituting the force into this equation, we derive x'' = -(ω0^2/m)x + (F0/m) + (kT/m). Initial conditions x(0) = d and x'(0) = v0 are used to solve for constants in the final expression for x(t), which is x(t) = -(ω0^2/m)(x-d)t + (kT/m)t^2/2 + c1t + c2, where c1 and c2 are determined from the initial conditions.
  • Understanding of differential equations
  • Familiarity with the concepts of harmonic motion
  • Knowledge of initial value problems
  • Basic calculus for integration
  • Study the derivation of the equation of motion for harmonic oscillators
  • Learn about solving second-order differential equations
  • Explore the effects of varying forces on harmonic motion
  • Investigate numerical methods for solving differential equations
Students and professionals in physics, engineers working on mechanical systems, and anyone interested in the dynamics of oscillatory motion.
jlmac2001
The question is: Solve for the motion of the undamped harmonic oscillator with an applied force F, treated in class, when the force is no longer constant but has the form F=F0+kT, where Fo and k are constants. Use the intial conditions x(0)=d and x'(0) =v0.
I'm trying to solve this problem using my notes but I don't see anything like it. What I'm thinking is that I need to find an equation of motion. Something like x(t)=x''+w0^2x=0, x(0)=x''+w0^2x=d, x'(0)=x''+w0^2x=v0. Help me!
You will need to end up with an equation of motion, but you can't start with one. You got to start with what you know, and all you know is force.
Use
[tex]F = m\ddot{x}[/tex]
where F is your given applied force. This gives you a differential equation that you must solve.
cookiemonster
To solve this problem, we can use the equation of motion for an undamped harmonic oscillator, which is:
x'' + ω0^2x = F/m
where x is the displacement, ω0 is the natural frequency, and F is the applied force. In this case, the force is no longer constant but has the form F = F0 + kT, where F0 and k are constants.
To find the solution, we first need to find an expression for F/m. Since we know that F = F0 + kT, we can substitute this into the equation of motion:
x'' + ω0^2x = (F0 + kT)/m
Next, we can rearrange this equation to isolate x'' on one side:
Now, we can use the initial conditions given in the problem to find the specific values for x(0) and x'(0). Substituting x(0) = d and x'(0) = v0 into the equation above, we get:
d'' = -(ω0^2/m)d + (F0/m) + (kT/m)
v0'' = -(ω0^2/m)v0 + (F0/m) + (kT/m)
We can solve these equations for d'' and v0'' and substitute them back into the equation of motion:
= -(ω0^2/m)x + d'' + (ω0^2/m)d + (kT/m)
= -(ω0^2/m)(x-d) + (kT/m)
Now, we can solve for x(t) by integrating the equation twice:
x(t) = -(ω0^2/m)∫(x-d)dt + (kT/m)t + c1
Finally, we can use the initial conditions to solve for the constants c1 and c2:
x(0) = d = c2
x'(0) = v0 = -ω0^2c2 + kT/m
c1 = (v0 + ω0^2d
