What is the moment of inertia for small blocks clamped to a light rod?
The problem involves calculating the moment of inertia for a system of small blocks clamped to a light rod. The setup includes blocks positioned at the ends and center of the rod, with the moment of inertia being computed about an axis perpendicular to the rod and located one third of the length from one end. The moment of inertia of the rod itself is neglected.
  • Exploratory, Mathematical reasoning
  • Participants discuss the distances of the blocks from the axis of rotation and how to incorporate these distances into the moment of inertia calculation. There is a focus on ensuring all blocks are accounted for in the calculations, particularly the block at the center of the rod.
Some participants are actively calculating the moment of inertia based on their understanding of the distances involved. There is an acknowledgment of the need to include the center block's contribution, and a few calculations have been presented, though no consensus has been reached on the final answer.
Participants are working under the assumption that the moment of inertia of the rod itself is negligible, which influences their calculations. There is also a mention of needing to square the distance for the center block, indicating a potential point of confusion or clarification needed in the calculations.
Edwardo_Elric
Small blocks with mass m, are clamped at the ends and at the center of a light rod of length L. Compute the moment of inertia of the system about an axis perpendicular to the rod and passing through a point one third of the length from one end.
Neglect the moment of inertia of the light rod.
[tex]\sum{I} = m_{1}r_{i} + m_{2}r_{i}...[/tex]
my answer would be
1/3 at one end and 2/3 because the other farther
I = m([1/3]L)^2 + m([2/3]L)^2
I = 1/9(mL^2) + 4/9(mL^2)
I = 5/9(mL^2)
There is another block at the centre of the rod.
so the block at the center has a distance of:
since it is at the center
1/2 - 1/3 = 1/6 is its distance from the end point
I = 1/9(mL^2) + 4/9(mL^2) + 1/6(mL^2)
I = 13/18mL^2
I = 13/18mL^2
you should have (1/6)^2
oh yeah thanks LP
  • · Replies 24 ·
