What Is the Square Root of i in Complex Numbers?
  • Thread starter Thread starter John O' Meara
    Complex
The square root of the imaginary unit \(i\) is expressed as \(\sqrt{i} = \exp^{\frac{\pi \iota}{4}} = \frac{\sqrt{2}}{2} + \frac{i\sqrt{2}}{2}\). This conclusion arises from the Euler's formula \( \exp^{iy} = \cos y + \iota \sin y\), where specific evaluations yield \(\exp^{\frac{\pi \iota}{4}} = \frac{1}{\sqrt{2}} + \frac{\iota}{\sqrt{2}}\). The calculations confirm that squaring this result leads back to \(i\), affirming that \(i\) has two square roots: \(\frac{\sqrt{2}}{2} + \frac{i\sqrt{2}}{2}\) and \(-\frac{\sqrt{2}}{2} - \frac{i\sqrt{2}}{2}\).
  • Understanding of complex numbers and their properties
  • Familiarity with Euler's formula and its applications
  • Basic knowledge of trigonometric functions
  • Experience with mathematical notation and operations involving imaginary units
  • Explore the properties of complex exponentiation and logarithms
  • Learn about the geometric interpretation of complex numbers
  • Study the concept of principal square roots in complex analysis
  • Investigate the applications of complex numbers in engineering and physics
Mathematicians, physics students, and anyone interested in complex analysis or the properties of imaginary numbers will benefit from this discussion.
John O' Meara
According to this equation [tex]\exp^{iy} = \cos y + \iota \sin y \mbox{ => } \exp^{\frac{\pi \iota}{2}} = \iota \ \mbox{,} \ \\ \exp^{\pi \iota} = -1 \ \ \exp^{\frac{-\pi \iota}{2}} = -\iota \ \ \exp^{2 \pi \iota} = 1 \\[/tex]. What then is [tex]\sqrt{\iota} = \iota^{\frac{1}{2}} \mbox{ equal to ?} \\[/tex]
Does not [tex]\exp^{\frac{\pi \iota}{4}}=\cos\frac{\pi}{4} + \sin\frac{\pi}{4} = \frac{1}{\sqrt{2}} +\frac{\iota}{\sqrt{2}} \ \mbox{ which is not =} \ \sqrt{\iota} \\[/tex]
I find it hard to see that it equals [tex]\exp^{\frac{\pi \iota}{4}}\\[/tex]. Help would be welcome. Thanks.
(1/sqrt(2)+i/sqrt(2))^2=1/2+2*i/(sqrt(2)*sqrt(2))-1/2=2*i/2=i.
Why do you think [itex]\sqrt{2}/2 +i\sqrt{2}/2[/itex] is not equal to [itex]\sqrt{i}[/itex]. Dick did the calculations but it's just a little bit hard to read. In Tex:
[tex]\left(\frac{\sqrt{2}}{2}+ \frac{i\sqrt{2}}{2}\right)\left(\frac{\sqrt{2}}{2}+ \frac{i\sqrt{2}}{2}\right)[/tex]
[tex]= \frac{\sqrt{2}}{2}\frac{\sqrt{2}}{2}+ \frac{i\sqrt{2}}{2}\frac{\sqrt{2}}{2}+ \frac{\sqrt{2}}{2}\frac{i\sqrt{2}}{2}+ \frac{i\sqrt{2}}{2}\frac{i\sqrt{2}}{2}[/tex]
[tex]= \frac{1}{2}+ \frac{i}{2}+ \frac{i}{2}- \frac{1}{2}= i[/tex]
Of course, like any non-zero number, i has two square roots. The other is
[tex]-\frac{\sqrt{2}}{2}-\frac{i\sqrt{2}}{2}[/tex].
14K
  • · Replies 21 ·
