Materials that produce Diffuse Acoustic Reflections
  • Context: Graduate
  • Thread starter Thread starter dimensionless
    Acoustic Materials
The discussion centers on the materials that produce diffuse acoustic reflections, exploring the conditions under which such reflections occur, including the role of surface features and acoustic impedance. It encompasses theoretical considerations and practical applications in acoustics.
  • Some participants inquire whether materials need large surface features to reflect acoustic waves diffusely or if smooth surfaces can also achieve this.
  • One participant suggests that variations in acoustic impedance may contribute to scattering, indicating that roughness typically needs to match the wavelength for effective diffusion.
  • There is a question about standard materials that diffuse sound, such as wood, concrete, and tile, and whether many construction materials exhibit non-uniform acoustic impedance.
  • Another participant notes that achieving significant diffusion with standard materials is challenging, emphasizing the importance of macroscopic irregularities and specific roughness requirements.
  • Quadratic residue diffusors (QRD) are proposed as a reliable method for achieving diffusion, with a recommendation to consider their absorption coefficients to avoid excessively low reverberation times.
Participants express various viewpoints on the conditions necessary for diffuse acoustic reflection, indicating that multiple competing views remain regarding the effectiveness of different materials and surface characteristics.
Limitations include the dependence on specific surface roughness and acoustic impedance configurations, as well as unresolved details regarding the effectiveness of various materials in practical applications.
dimensionless
Are there certain materials that reflect acoustic waves diffusely? Would the material need to have large (visible) surface features to produce this kind of reflection or can the surface be smooth? Are there materials that reflect acoustic waves in accordance with Lambert's cosine law?
Science news on Phys.org
Constructions that do this are commercially available, see for example http://www.rpginc.com/
Not necessarily - variations in acoustic impedance may also produce scattering.
For non-smooth surfaces: The roughness usually needs to be of the same order as the wavelengths for efficient diffusion.
Thank you for your reply.
Are there standard materials that diffuse (e.g. wood, concrete, tile, wall board, etc.)?
Are there many contruction materials that have non-uniform acoustic impedance?
It is difficult to achieve uniform and significant diffusion with standard materials - the dominant factor is rather the macroscopic irregularities (required roughness typically about 30 cm for 1 kHz).
Non-uniform acoustic wall impedance is effected by placing many patches of different materials (and/or different air gaps behind them) close to each other. Each patch may have constant acoustic wall impedance over its own surface.
The safest method is however probably to use quadratic residue diffusors (QRD) with documented values of diffusion coefficients. It is also important to keep track of the absorption coefficient of the diffusor, so that the reverberation time doesn't become too low by mistake.
22K
