Vector Change in Velocity: What is the Resultant Velocity after a Right Turn?
  • Thread starter Thread starter henry2221
    Vector
The problem involves a car's change in velocity as it makes a right turn, transitioning from traveling south at 60 km/h to traveling west at 80 km/h. The focus is on understanding the vector nature of velocity and how to calculate the change in velocity vectorially.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the distinction between velocity and speed, emphasizing the vector nature of velocity. There are attempts to compute the change in velocity vectorially and questions about the correct representation of vectors. Some participants suggest drawing diagrams to visualize the problem.
The discussion is ongoing, with various participants providing insights into vector representation and urging the original poster to draw diagrams. There is no explicit consensus yet, but guidance has been offered regarding the need to consider both magnitude and direction in vector calculations.
Participants note the importance of directional information in vector calculations and question the original poster's approach to handling negative signs and units. There is also mention of homework constraints regarding the method of solving the problem.
henry2221
A car proceeding due south at 60 km/h (V1) makes a right turn, after which it is traveling due west at 80 km/h (V2). What is its change in velocity (V2-V1)?
(V2-V1)
I obviously did 80 km/h - 60 km/h = + 20 km/h. However this is wrong. I don't see why, but it is wrong. The instructor mentioned solving this geometrically or something like that, but I have no clue what they're talking about.
You are confusing velocity (a vector quantity) with speed (a scalar quantity). Its an easy trap to fall into as we use the two terms colloquially to mean the same thing. I assume your instructor wants you to compute the magnitude of the change in the velocity vector, so in a sense he has been caught in the same trap.
Can you compute v2-v1 as a vector and then take its magnitude?
You need to read about vectors in your course materials. Velocity is a vector; it has both magnitude and direction. If we take east as the positive x direction, and north as the positive y direction, then the x component of V1 is 0, and the y component is -60 km/h. I could also specify V1 by its magnitude (60 km/h), and by the angle an arrow pointing in the direction of motion makes with the positive x-axis (90 degrees, or pi/2 radians).
So basically it means,
(-80 km/h West) - (-60 km/h South) = -20 km/h
First, why did you add those negative signs, and second, why did you throw away the directions?
I'm going to ask a different question: A car travels due south 60 km, turns to the west, and travels another 80 km. How far is the car from the starting point?
The answer is not 140km, nor 20km, nor anything like that. Don't throw away the directional information because that is one of the two things that make a vector a vector.
I added those negative signs because in vectors south and west are considered negative in terms of magnitude? And I didn't throw away the directions? What did you mean? I mentioned the course of direction for each vector.
(-60 km due south)i + (-80km due west)j = -140 km due south west
http://www.glenbrook.k12.il.us/GBSSCI/PHYS/CLASS/1DKin/U1L1d.html
Are you just trying things at random now? You "mention" the course of direction but do nothing at all with it! Also, by the way, the units are NOT "km", they are "km/hr". YOU said that this was a vector problem. Why haven't you used vectors at all?
Draw a picture. Draw a vector "60 km/h" due south. In other words, pick some convenient scale (say a cm for each 10 km/h) and take "due south" to mean "down" on your paper. You have a line segment (arrow) 6 cm long going down. At the origin (beginning point) of that arrow, draw another "80 km/h due West". That would be a line segment (arrow) 8 cm long pointing to the left. Now draw the segment connecting the origin of the tips of the two arrows. That vector is their difference. You will need to give both its length (that's easy- think "3-4-5" right triangle) and the angle it makes (a bit harder- you will need trig functions).
Mea culpa! I thought Henry might be able to deal with the slightly different and more concrete problem of adding displacement vectors. My hope was that he would have readily answered my question in post#5. My plan was to then move him back to the original problem of adding velocity vectors. The best laid plans ...
Henry, please follow Halls' advice. Draw a picture.
(V2-V1)
I believed this might have been mentioned... You have to make a triangle with the vectors... Vectors are drawn head to tail... So your resulting Vector will point South West... You can use pythagorean theorem to find the resulting velocity... very difficult to explain vectors without drawing diagrams :(
Why would I need to make a triangle when the problem is only asking for the change in velocity, it's not asking for the resultant. But i'll do that anyways. I'll post it tommorow.
Because the change in velocity is (directly related to) the magnitude of the resultant :)
You beat me to it. :)
Would I use the avg velocity to find the change in velocity?
with the change in distance over time?
(-80 km) west - (-60 km) south / 2h - 0 h
thus
-20km/2h = -10 km/h due south west?
is this right?
Why are you refusing to do what everyone here has asked you to do, which is draw a picture? This is a vector problem, you need to use vectors. You have'nt done that yet.
To answer your question, the result in post #13 is not right.
I drew it. So am I suppose to find the resultant? Or...?
That drawing is not quite right. It shows how to graphically compute V1+V2 (the vector along the hypotenuse). You want V2-V1. At least you have the magnitude correct now.
  • · Replies 18 ·
