| Thread Closed |
Average speed & average velocity Problem |
Share Thread | Thread Tools |
| Oct3-07, 11:28 PM | #1 |
Brandon is climbing a mountain. He starts from an elevation of H1=511m above sea level. In 6.18 hours he climbs to an elevation of H2=2746m above sea level. The length of his path is L1=16000m. A)What is the average angle of ascent the path makes with the horizontal?Theta= B)What is his average speed along the path in meters/second? average speed= C)What is his average vertical velocity? Vup= D)After he eats he hikes back down to their starting point in T2=4.24 hours What is his average vertical velocity? Vdown= 2. Relevant equations avg speed=total distance/total time avg velocity=v=Delta x/delta t tan theta=opposite/adjacent 3. The attempt at a solution A)tan theta=opposite/adjacent Im so confused as to what equations to use. B)avg speed= total distance/total time 16000M/22680S=0.705m/s C)avg velocity=v=Delta x/delta t D)Confused on D as well Please give some suggestions or the correct equations will be great.thanx Dave |
| Oct4-07, 12:22 AM | #2 |
Recognitions:
You are on the right track. If you haven't done it already, one thing that helps is to draw a picture.
For a, you have the correct equation. Hint: what does L1 represent in a simple idealized geometric shape? For c & d: be careful. The problem says average vertical velocity. Also, looks like you double posted by mistake.
| Oct4-07, 10:08 AM | #3 |
Hotvette thanx alot for the help just got a few more questions.
If your talking in terms of a triangle L1 would represent my hypotenuse I believe. So would 16000m be my hypotenuse is what your suggesting. But dont I have to choose the equation involving the hypotenuse to find the angle. Like: sin theta= opp/hyp or cos theta= adj/hyp But my question is what is the equation for vertical velocity? Thanx Vette |
| Oct4-07, 10:17 AM | #4 |
Recognitions:
For the angle yes, use:
sin theta = opp/hyp average vertical velocity = vertical displacement/time |
| Oct4-07, 10:29 AM | #5 |
Thank you learn,
But im wondering if my hyp=16000m and im trying to find theta. whats my opp or how do i find my opp.? |
| Oct4-07, 10:38 AM | #6 |
Recognitions:
| Oct4-07, 11:15 AM | #7 |
Thanx Learn,
Ok so if I subtract the H2=2746m- 511m=my distance is 2235m So to find theta I did this: sin theta=opp/hyp sin theta=2235m/16000 theta=7.98 degrees or 8 degrees Please tell me this is correct |
| Oct4-07, 11:25 AM | #8 |
Recognitions:
| Oct4-07, 11:40 AM | #9 |
Thanx,
For my average speed =total distance/total time,do I use the 16000m for total distance/6.18hrs or do i convert hrs to seconds. Since my answer has to be in m/s? |
| Oct4-07, 11:45 AM | #10 |
Recognitions:
Yeah, I think converting to s is best. otherwise your answer will be in m/hr... best to use m/s.
| Oct4-07, 12:42 PM | #11 |
Question so if vertical speed= deltaV/T,would my deltaV= .705m/s?I got .705m/s from my average velocity equation which was 16000m/22680s=.705m/s for avgV. Is average vertical velocity and vertical velocity the same equation?
| Oct4-07, 01:34 PM | #12 |
Recognitions:
vertical velocity is vertical displacement which you know is 2235m divided by time.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Average speed & average velocity Problem
| Constant velocity questions (average speed vs. average velocity) | Introductory Physics Homework | 2 | ||
| Average speed & average velocity Problem | Introductory Physics Homework | 1 | ||
| Average Speed vs. Average velocity | Introductory Physics Homework | 41 | ||
| Average speed and average velocity?? | Introductory Physics Homework | 1 | ||
| Average Speed/Average Velocity Problem | Introductory Physics Homework | 4 | ||
