Ballistic pendulum and initial speed
The discussion revolves around a ballistic pendulum problem where an object of mass m is fired at a pendulum bob of mass M. The goal is to find an expression for the initial speed v_0 of the fired object in terms of various variables, including mass, length, angle, and gravitational acceleration.
  • Participants discuss the conservation of momentum during the inelastic collision and the conservation of mechanical energy as the pendulum swings. There is confusion regarding how to incorporate the angle theta into the calculations, particularly in expressing height h in terms of theta.
Participants are actively exploring the relationship between the height h and the angle theta, with some suggesting the use of trigonometric relationships to express h. There is a collaborative effort to clarify the geometry involved in the problem.
There is a constraint regarding the use of the variable h, prompting participants to seek alternative expressions using theta. The problem setup involves both momentum conservation and energy conservation principles.
jaded18
In a ballistic pendulum an object of mass m is fired with an initial speed v_0 at a pendulum bob. The bob has a mass M, which is suspended by a rod of length L and negligible mass. After the collision, the pendulum and object stick together and swing to a maximum angular displacement theta as shown http://session.masteringphysics.com/problemAsset/1010989/26/1010989A.jpg
Find an expression for v_0, the initial speed of the fired object.
Express your answer in terms of some or all of the variables m, M, L, and theta and the acceleration due to gravity, g.
_____
i know that there are two events. the first one is the inelastic collision, where momentum is conserved and mv = (m+M)(V) ... and V = mv/(m+M) ... and when the block swings up mechanical energy is conserved so that (K initial + U initial) = (K final + U final) and (0.5(m+M)V^2) = (m+M)g(h) ... and the bullet speed is ((m+M)/m)(sqrt 2gh) ... how do i incorporate this theta variable that the problem is asking for?
i am so confused!
maybe they want me to change h into terms using theta since the problem is not accepting the variable h ... but how do i do this?
use trig. when the pendulum as swung, how far below the pivot is the bob located? you have a right triangle with hypoteneuse L and angle theta.
i'm sorry but i don't see it ... i can say cos theta = adj/L and but then what's the 'adj'??
oh! wait .. so L-Lcos theta = h?
yes exactly.
thanks, it seems like you're always there for me when I'm stuck .. thanks again~
:smile: no prob!
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 17 ·
