What is the voltage in kV across each capacitor?
  • Thread starter Thread starter at3rg0
    Capacitor Voltage
The problem involves two capacitors, one with a capacitance of 150 pF and the other with 600 pF, both charged to 3.3 kV. After being disconnected from the voltage source, they are connected together with opposite polarities. The questions focus on determining the voltage across each capacitor after connection and the energy lost during the process.
  • Participants discuss the charge on each capacitor before connection and the implications of connecting them in parallel. There are questions about calculating the final voltage across the capacitors and how to account for energy lost during the connection.
Participants are exploring various calculations related to charge, voltage, and energy. Some have provided specific numerical values and methods for calculating energy, while others are clarifying concepts related to capacitor connections and energy loss. There is an ongoing exchange of ideas without a definitive consensus on the final answers.
There are mentions of potential confusion regarding units of charge (microC vs. nanoC) and the need to ensure accurate calculations for energy lost. Participants are working within the constraints of the problem without additional external information.
at3rg0
A 150 pF capacitor and a 600 pF capacitor are both charged to 3.3 kV. They are then disconnected from the voltage source and are connected together, positive plate to negative plate.
a) What is the voltage in kV across each capacitor?
b) How much energy is lost (in mJ) is lost when the connection is made?
Q = CV
Connection in parallel: C (total) = C1 + C2
Between all the formulas I have gotten anywhere from 9.9 kV to 19.8 kV and just about everything in between. I am just short of tearing my hair out.
First step... what is the charge on each capacitor before they are connected together?
1980microC and 495mC, right?
If they're connected parallel,final charge on them must be equal.
yes, but they should be nanoC.
Now they are connected positive to negative... so 1980nC is connected to -495nC... we have the two capacitors in parallel with a net charge of 1980 - 495 nanoC = 1485nC...
what is the equivalent capacitance of two capacitors in parallel... hence what is the voltage across the two capacitors?
now you can get the energy in the capacitors connected in parallel... compare to the initial energy.
So, in parallel, they'll be added?
So, divide by the sum of the two capacitances? Does that give me the voltage on both?
Okay, so the answer is right.
Each has 1.98kV.
However, how would I account for the Energy lost?
yes, it gives the voltage on both.
Okay, and I used U=.5CV^2 to get the energy. Thanks so much!
no prob! did you calculate the energy lost?
Yeah, it was easy. I just did:
.5(195E-12)(3.3E3^2) + (.5(600E-12)(3.3E3^2) - Final Energy (I forget the value), and got the solution.
cool! yup, that's the way to get it.
  • · Replies 19 ·
