How Do You Calculate the Magnitude of a Magnetic Field from Current and Force?
  • Thread starter Thread starter phystudent
    Magnetic
The discussion revolves around calculating the magnitude of a magnetic field from given current and force parameters in a physics context, specifically related to magnetism.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants express uncertainty about how to begin solving the problem, with some seeking formulas that relate current, force, and magnetic field. Others discuss the relationship between force, velocity, and magnetic field, suggesting the use of cross-product in the context of magnetic forces.
There is a mix of attempts to clarify concepts and explore relevant equations. Some participants have provided insights into the relationships between the variables involved, while others are still grappling with the foundational aspects of the problem.
Participants mention a lack of guidance from instructional materials and express the need for clarification on the meanings of terms and concepts related to the problem.
phystudent
I need help, I have no idea how to even start?
A 17 A current is directed along the positive x-axis and perpendicularly to a uniform magnetic field. The conductor experiences a magnetic force per unit length of 0:57 N=m in the negative y direction. Calculate the magnitude of the magnetic field in the region through which the current passes. Answer in units of T.
Okay, so here, you are given the force per unit length, the current, and the direction. You need to figure out the B-field. Do you know of any formulas that might work here? Be careful of directions!
I have no idea what to do...my teacher gave me nothing If you could give me a formula and tell me what things mean that would be very helpful
Okay, so we know that if you have a particle moving in a magnetic field, it will experience a force. The direction of the force is perpendicular to that of the velocity and the magnetic field. Hence, the formula must have a cross-product. A general force equation is F = (q) (v) x (b) where q=charge, v=velocity, and b=magnetic field. In your case, you are given some current wire. Current is dQ/dt, and if you manipulate the above equation correctly, you will get something like: F = (I) (L) x (B). where I= current, L=length and B= b-field. In your case, you are given F/L, so all you need to do is divide the F/L by I and get your B-field.
I think that in order to solve any of these problems, you should first try and understand the cross product and the direction. you will encounter them throughout your study of magnetism.
