Kinematics of 2-D Ball Rolling Off Table
The discussion focuses on the kinematics of a ball rolling off a 1.90 m high table and striking the ground 1.57 m away horizontally. The user initially attempted to solve for the time in the air using the quadratic equation but found discrepancies in their calculations. Ultimately, they resolved the problem using kinematic equations, highlighting the importance of correctly setting up equations in physics problems. The user recognized that their initial quadratic setup was incorrect, which led to confusion in obtaining the correct answer.
  • Understanding of 2-D kinematics principles
  • Familiarity with kinematic equations
  • Knowledge of the quadratic formula
  • Basic concepts of projectile motion
  • Review the derivation and application of kinematic equations in projectile motion
  • Practice solving problems involving the quadratic formula in physics contexts
  • Explore the effects of air resistance on projectile motion
  • Learn about the relationship between vertical and horizontal motion in 2-D kinematics
Students studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion and its mathematical applications.
jedjj
2-D kinematics[solved]
A ball rolls horizontally off the edge of a tabletop that is 1.90 m high. It strikes the floor at a point 1.57 m horizontally away from the table edge. (Neglect air resistance.)
(a) How long was the ball in the air?
(b) What was its speed at the instant it left the table?
2. The attempt at a solution
I have been trying to get the answer to part a for a little while now. I have been trying to use the quadratic equation to find time knowing that [tex]0=(-\Delta y)+V_{0y}*t+(g)t^2[/tex]
I have not used quadratic equation in about 4 years. Am I setting this problem up correctly when I do
[tex]t=\frac{V_{0y}+\sqrt{V_{0y}^2-(4)(-\Delta y)(g)}}{2*(g)}[/tex]
which should give me
[tex]t=\frac{{0}+\sqrt{0^2-(4)(-1.9)(g)}}{2*(g)}[/tex]
[tex]t=\frac{\sqrt{-(4)(-1.9)(g)}}{2*(g)}[/tex]
which comes to be
[tex]t=\frac{8.63}{19.6}[/tex]
[tex]t=0.4403[/tex]
I am not coming up with the correct answer according to what it is online[edit:still]. What am I doing wrong? Thanks for all the help.
[edit] I just went ahead and used kinematic equations and found the answer, but I'm still confused why the quadratic equation didn't work.
To start I just realized that quadratic equation is not set up properly. I will edit the equation and set it up in the way that I believe is proper.
Am I giving too much information, or not enough. or is no one seeing a mistake I am making?
  • · Replies 21 ·
