Pd across resistors, can u explain the following?
The discussion revolves around the concept of potential difference (pd) across resistors in a circuit, particularly focusing on the implications of adding a parallel resistor to a series circuit. Participants explore the conceptual understanding of how electrons behave in such circuits and the challenges of explaining these concepts to students.
  • One participant describes a circuit with a 12-volt power supply and two 2-ohm resistors in series, noting that the pd across each resistor is 6 volts. They explain how adding a third 2-ohm resistor in parallel with one of the series resistors changes the pd across the resistors.
  • The same participant raises a conceptual challenge regarding the analogy of an electron moving through resistors, questioning why the introduction of a parallel resistor seems to ease the pathway for electrons, despite the idea that each electron only takes one path.
  • Another participant suggests abandoning the "one electron" analogy, referencing an external educational resource for clarity.
  • One participant proposes that the parallel connection offers a wider path, making it easier for electron flow.
  • Another participant likens a resistor to a restriction, stating that with two equal parallel resistors, the overall restriction is halved, thus allowing for increased current flow.
Participants express differing views on the appropriateness of the "one electron" analogy and its implications for understanding potential difference in circuits. There is no consensus on a singular explanation that satisfies all participants.
The discussion highlights the complexity of explaining electrical concepts at a fundamental level, particularly regarding individual electron behavior versus collective charge movement. Limitations in the analogy and its effectiveness in teaching are acknowledged but remain unresolved.
Educators and students seeking to deepen their understanding of electrical circuits, particularly in the context of potential difference and electron behavior in series and parallel configurations.
deem
In a circuit that has a 12volt power supply and two 2- ohm resistors, R1 and R2, in series, the pd across each resistor is obviously 6v.
If a 3rd resistor (also 2-ohm)R3, is placed in parallel across R2 then the pd across them changes to the following:
R1=8v R2=4v= R3 (parallel)
However, when I am explaining pd to my students I ask them to imagine they are a single electron, that has to make its way thru the resistors, and has to do a lot of work, and loses elec potential energy as a result. This works very well for series circuits, but the above calculations blow my analogy out of the water, because I inevitably get the “well, if it is a single electron and only takes ONE pathway, then why does it seem easier to get thru the parallel portion of the circuit? Ie. In the original series circuit the electron had to expend half “energy” to get thru the 2-ohm resistor, but just cos a new one is introduced, it eases the pathway thru the second, and now it spends 2/3 of its energy going thru the first resistor and only 1/3 going thru the second.”
In other words, just because another route has opened, this should have no bearing on how hard it is to get thru the very FIRST resistor R1. Also, if an electron takes ONE route (R2), it is completely unaware of the parallel route (R3), and should still have to work just as hard to get thru the R2 as it originally did.
I can explain it properly when we are talking about coulombs because I say that the overall work done by the coulomb is “shared” along the two paths (but I am not even totally happy with that explanation myself!) but surely it should work for individual electrons just as much, and yet each electron takes ONLY ONE path!
Is it because the sheer number of electrons going thru has been reduced so that somehow reduces the work an individual electron has to do, since it is less “crowded” en route?
I understand all the Ohm’s Law calculations, but I really would like a conceptual explanation on a single-electron level that would also explain it in terms of a charge having to battle its way across a crowded resistor surface.
Sorry to have been so longwinded. I have asked several teachers and I have not got any satisfactory response, and if u can help me out at all, I would really apprec.
I would forget the "one electron" idea. A lot of educators use http://www.allaboutcircuits.com/vol_1/chpt_2/2.html.
Regards
You can explain that by saying that the parallel connection provides a wider path. So it is easier for the electron flow through it.
Yes. A resistor would be like a restriction. With two equal parallel resistors you would have half the restriction (hence twice the cross-section/path).
  • · Replies 21 ·
