Coefficient of sliding friction homework
The discussion revolves around problems related to forces, friction, and acceleration in physics. The original poster presents two scenarios involving a package being pushed across a gym floor and a box being slid up a ramp, both requiring calculations of normal force, frictional force, and coefficients of friction.
  • Mixed
  • Participants explore resolving forces into horizontal and vertical components, questioning how to apply these to find normal and frictional forces.
  • Some participants seek clarification on the relationship between applied forces, friction, and net force in both scenarios.
  • There is an inquiry into the percentage of force wasted due to the angle of application in the first problem.
Participants are actively engaging with the problems, providing insights and guidance on how to approach the calculations. There is a recognition of the need to resolve forces correctly and to understand the relationships between them, although no explicit consensus has been reached on the final answers.
Participants note the importance of considering the vertical component of applied forces and the weight of the objects in determining normal and frictional forces. There is also mention of the need to adhere to homework constraints while discussing the problems.
brad_i2001
A large package weighing 517 N is accelerated across a gym floor at 3 m/sec^2 because it is being pushed at a force of 285 N at 50 degrees to the floor. What is the normal force of the package? What is the coefficient of sliding friction between the package and the floor? Approximately what percentage of the 285 N force is being wasted due to the excessive angle produced by the pusher?
F=MA
HORIZONTALLY
FORCE APPLIED, X= (285)(cos 50)= 183.194
VERTICALLY
FORCE OF Y=0 (not rising off the ground)
FORCE APPLIED, Y= (285)(sin 50)= 218.323
I have filled in as much as I know, please help!
Thanks
To slide a 400 N box up a 25 degree ramp at a constant speed, a force of 250 N is required. What is the net force of the box? What is the frictional force on the box? What is the coefficient of friction between the box and the plane?
Horizontally
Fg,X=(9.81)(cos 25)= 8.89 N
FX= Fg,X-Force of Friction
Vertically
Fg, Y= (9.81)(sin 25)= 4.145 N
I am still unsure how to put these products into a formula.
Thanks for your help!
F=MA
HORIZONTALLY
VERTICALLY
Thanks
So you've resolved the force horizontally and vertically. Let's address the question of kinetic friction. The friction when two surfaces slide over another is constan and is the product of the coefficient of friction and the normal force. You will have to work out the force due to friction which is where the acceleration of the package comes in, and then the normal force. This will allow you to work out the coefficient of friction.
For the percentage waste compare the force actually going into accelerating the box here with the force that would be going into accelerating the box had the force been applied completely horizontally.
Horizontally
Vertically
The weight of the box is 400N which is given by W = mg. Work out the component of weight parallel to and perpendicular to the ramp. The component of weight parallel must be balanced with the friction by the applied force. The friction is found similarly from the normal as above.
So,
NET FORCE
=250 N
VERTICAL
Y Component= (250)(sin 25)=105.654
HORIZONTAL
X Component= (250)(cos 25)=226.576
For problem 2, how do I finish finding friction?
You want to resolve the components of the weight of the box which is 400 N not the net force. The net force will be the sum of the frictional force and the component of weight parallel to the ramp.
To find the friction force you will need to find the weight of the box parallel to the ramp. Once you have that you know that friction plus weight is equal to the 250 N force acting on the box. You will also know the normal force from resolving the weight and you can then find the coefficient of friction.
Net Force = Frictional Force + Weight Parallel
250 = Frictional Force + 226.576
23.424 = Frictional Force
Is this correct?
Once Again, THANKS FOR YOUR HELP AND QUICK RESPONE!
The weight is 400N not the 250 Newtons net force. So you need 400 sin (25) to find the weight parallel to the ramp. The method however is correct.
THANK YOU SO MUCH!
Is the first problem solved in the same way?
The first question is similar. You have resolved the forces correctly but be careful because the normal force will be the weight plus the extra component of the force acting veritically downward on the package. To work out the friction wou need to find the frictional force by subtracting the component of force horizontally from the force needed to accelerate the package at 3m/s2. Then to find the final piece of information proceed as I suggested in my first post.
So,
Normal Force = 517 - (517x9.81)
Normal Force = 4554.77
Force of Friction = 183.194 - 285
Force of Friction = 101.806 N
Is this correct?
THANK YOU SO MUCH!
Normal force is the weight (517 N) + the vertical component of the applied force which you worked out as 218.323N.
Now: Frictional force = force applied - force required for 3m/s{sup]2[/sup] acceleration.
Can you take it from there?
I think I got it. THANK YOU for your help. I appreciate it!
  • · Replies 20 ·
  • · Replies 16 ·
