Thread Closed
Dynamics of block with friction...how to set up?
Share Thread Thread Tools
Oct7-07, 05:29 PM   #1
a 2.0 kg wood box slides down a vertical wood wall while you push on it at a 45 degree angle. what magnitude of foce should you apply to cause the box to slide down at a constant speed? I know that Mk = .2 (wood on wood)
2. Relevant equations
3. The attempt at a solution
I tried to solve it with setting the forces in the y direction. I keep getting it wrong. i said Fy=0=Fasin[tex]\vartheta[/tex] - 19.6 N then solved and got Fa = 27.71 N. however the answer is Fa = 23.1 N
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct7-07, 09:37 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by fizziksc View Post
You have to look at all forces in the y direction. You missed one. You're going to have to look for all forces in the x direction as well.
Thread Closed
Thread Tools
Similar Threads for: Dynamics of block with friction...how to set up?
Thread Forum Replies
simple harmonic motion, spring, block on block, static friction help Introductory Physics Homework 4
block with friction Introductory Physics Homework 0
Dynamics block problem Introductory Physics Homework 1
Rotational Dynamics - sphere,block,pulley Introductory Physics Homework 1
