Series Estimation: Estimating Terms Needed to Reach |Error|<0.001
  • Thread starter Thread starter fsm
    Series
The problem involves estimating the number of terms needed in the alternating series \(\sum\frac{(-1)^{x}}{x*\sqrt{x}}\) to achieve an error less than 0.001. The context is within the study of series convergence and error estimation.
  • Participants discuss the conditions for applying error estimation methods, particularly focusing on the continuity and monotonicity of the function involved. There is mention of comparing the series to a p-series and considerations about the behavior of the terms.
Some participants have offered guidance on using properties of alternating series to estimate the error, while others express uncertainty about the function's characteristics. The discussion reflects a mix of interpretations and approaches without a clear consensus on the next steps.
There is a noted concern regarding the function's positivity and decreasing nature, which are critical for applying certain convergence tests. The original poster also expresses frustration with the problem setup.
fsm
[tex]\sum\frac{(-1)^{x}}{x*\sqrt{x}}[/tex]
How many terms must be added to get an esimate with an |error|<0.001?
[tex]s_n+ \int f(x)dx \leq s \leq s_n+ \int f(x)dx[/tex]
I having some problems trying to attempt this. To use this the function must be continuous which it is. Then it has to be positive and decreasing--this to me is the rub. The graph is symmertic at the horizontal asymptote x=0. So part of the graph is negative and increasing. I feel like I hit a brick wall. The only other thing I can think of is to rewrite the demoninator as x^(3/2), compare to a p-series and then find how many terms.
anyone?
There's a generic method for alternating series you can use to easily answer this question.
Since, as NateTG said, this is an alternating sequence, the error, after n terms can't be more than the difference between the last two terms. Plot a few terms on a number line to convince your self of this.
Thanks everyone for the help. I thought that originally but second guessed myself. And I got the answer.
