Calculating Force of Water Resistance on a Motorboat
The discussion focuses on calculating the force of water resistance acting on a motorboat that develops 50 kW of power while covering a distance of 1 km in 6 minutes. Using the power equation P(t) = F(t) · v(t), where F is the force and v is the velocity, participants suggest that the resistance force can be determined by first calculating the boat's velocity and then applying the power formula. The key takeaway is that the resistance force can be derived from the relationship between power, distance, and time.
  • Understanding of basic physics concepts, specifically Newton's laws of motion.
  • Familiarity with power calculations in physics, particularly the relationship between power, force, and velocity.
  • Knowledge of differential equations and their application in physics problems.
  • Ability to perform unit conversions, particularly from kW to Newtons.
  • Calculate the velocity of the motorboat using the formula: velocity = distance/time.
  • Apply the power formula P = F · v to find the force of water resistance.
  • Explore the concept of drag force and its relation to watercraft performance.
  • Investigate the effects of different hull designs on water resistance and efficiency.
Students studying physics, marine engineers, and anyone interested in understanding the dynamics of motorboat performance and water resistance calculations.
lindzpooh
hlpe please!
a motorboat that develops 50kW covers a distance of 1km in 6min. with how much force did the water resist the motion of the boat?
I would use your definitions.
[tex]P(t) =\frac{dW}{dt} = \frac{d}{dt} \int \mathbf{F} \cdot ds = \mathbf{F}(t) \cdot \mathbf{v}(t)[/tex]
You have to try something. Basically, with the information you have provided, you could be able to solve differential equations for all I know.
  • · Replies 39 ·
