Angular Impulse and Angular Momentum
The discussion focuses on calculating the angular velocity (w) of an arm after a plug has wedged itself into a block, given specific parameters such as mass, distance from the pivot point, and initial angular velocity. The user applied the equations of motion and angular momentum principles to derive w, concluding it to be less than 2 rad/s, which is noted as a clockwise (CW) direction. The significance of the 2 rad/s value is questioned, indicating it may represent a threshold or expected value for the system's behavior.
  • Understanding of angular momentum principles
  • Familiarity with kinematic equations, specifically v^2 = vo^2 - 2g(y-yo)
  • Knowledge of angular velocity calculations
  • Basic concepts of mass distribution and pivot points in mechanics
  • Study the conservation of angular momentum in mechanical systems
  • Learn about the significance of angular velocity thresholds in dynamics
  • Explore the effects of mass distribution on angular motion
  • Investigate real-world applications of angular momentum in engineering
Students in physics or engineering, particularly those studying mechanics, as well as educators seeking to clarify concepts of angular momentum and velocity in practical scenarios.
krnhseya
Mass of both end, distance from the pin point, height of the plug and its mass, angular velocity are given.
Need to fine angular velocity w of the arm immediately after plug has wedged itself in the block.
(Ho)o = (Ho)horizontal
1) 2(v1)(0.5) = (4+2)(0.5w)(0.5) + 6(0.3w)0.3
2) v^2 = vo^2 - 2g(y-yo) -> calculate v and substitute in v1
I find w to be a number smaller than 2 rad/s which is given and i know it's CW.
I just want to double check my work. thanks.
if someone can guide me to right direction i'd really appreciate it. :)
whats the significance of 2 rad/s?
18K
