Space station orbit gravity help
The discussion revolves around a problem involving gravitational forces acting on a space station located between the Earth and the Moon. Participants are tasked with determining the distances from the space station to both celestial bodies based on the condition that the gravitational forces from each are equal.
  • Participants discuss the gravitational forces and their equilibrium conditions, with some attempting to set up equations based on the forces involved. There are also questions about the correctness of values used for distances and masses, as well as the interpretation of the problem's parameters.
The discussion is ongoing, with various participants providing calculations and questioning the accuracy of their results. Some have offered corrections regarding the values for the mass and radius of Mars in a related question, while others are clarifying the distances involved in the original space station problem.
There are discrepancies noted regarding the distance between the Earth and the Moon, with some participants referencing different values. Additionally, there is confusion about the calculations leading to the distances from the space station to the Earth and Moon, indicating a need for careful verification of the arithmetic involved.
pinkyjoshi65
A space station is in orbit between the Earth and the moon. The force due to gravity on the space station from the moon is the same as the force due to gravity from the earth. How far away from the Earth is the speace station? How far from the moon is the space station?
What are your thoughts on the question?
i tried doing the question, but got stuck in it. I found F_gm and F_ge. Then i equated them. i ended up with r/R=0.11045, where r=dist. between the satelite and the moon, and R=dist. between the satellite and earth.
Good so far. Now use the distance between the Earth and the moon and set this equal to r + R... look up the distance between the Earth and the moon.
so by doing that, i got the R=346168670.4m and r=38234329.6m
Looks good to me.
i had another question: Mars has 54% the mass of the Earth and a radius 11% of the earth. what is g on mars? what i did for this was
M_m=0.54M_E, R_m=0.11M_E
g=GM_m/R_m^2
g=G*0.54M_E/0.11R_E
g=(6.67*〖10〗^(-11)*0.54*6* 〖10〗^24)/(〖0.11*6.37*〖10〗^6)〗^2
g=21.61*〖10〗^13/0.49*〖10〗^12
g=44.102*10= 441.02m/sq sec
But when i searched the net for the g on mars..i found out tht the g is 3.77m/sq. sec
You must have mixed the radius and mass of mars. Mars has 11% of Earth's mass, and 54% of Earth radius.
You should have looked up that too =)
Incedently, you can work this one out without looking up any values. You know that g is proportional to m and inversely proportional to the square of r, hence you can write;
[tex]g_m = \frac{0.11}{0.54^2}\cdot g_e[/tex]
so the question is wrong?
The question as written above in post #7 is incorrect. As malawi_glenn correctly states, the mass of Mars is approximately 11% of the Earth's and mars' radius is approximately 54% of the earth's.
Data I used:
Mass of Earth = 6.02 x 10^24 kg = Me
Mass of Moon = 7.34 x 10^22 kg = Mm
Let R = distance between Earth and station, r =distance between Moon and station
At equilibrium,
Force acting on station by Earth = Force acting on station by Moon
GMeM / R^2 = GMmM / r^2
r / R = sqrt (Mm / Me )
= 0.1104
And knowing R + r = distance between Earth and Moon = 3.844 x 10^9 m,
R = 3.367 x 10^9 m
r = 4.77 x 10^8 m
Station is closer to Moon than to Earth.
r+R is supposed to be equal to 3.84*10^8m. How did u get r+R =3.84*10^9m??
The sources I have agree with 3.84*10^8m.
also i got r= 3.82*10^7m not 4.77*10^8m. Which one is right?
Forgive me, but I'm not checking through the arithmetic; I'm assuming that if thiotimoline used an incorrect value, his/her final result will be incorrect.
Thanks..:)
pinkyjoshi65 said:
Thanks..:)
Pleasure :smile:
thiotimoline said:
Data I used:
At equilibrium,
= 0.1104
And knowing R + r = distance between Earth and Moon = 3.844 x 10^8 m,
R = 3.48 x 10^8 m
r = 3.64 x 10^7 m
This is the correct ans, kindly ignore my previous post. I apologise for the mistake. :)
  • · Replies 21 ·
