Calculating Tension and Force on a Car on a Smooth Ramp - Help Guide
  • Thread starter Thread starter saturn67
    Tension
The discussion revolves around calculating the tension in a cable and the normal force acting on a car positioned on a frictionless ramp. The car has a mass of 1200 kg, and the ramp is inclined at 25 degrees while the cable makes an angle of 31 degrees with the ramp's surface.
  • Mixed
  • Participants discuss breaking down forces into components along and perpendicular to the ramp. There are attempts to establish equations for the forces in both directions, with some questioning the correct angles to use for calculations.
The conversation includes various equations being proposed and modified, with participants exploring the components of tension and the normal force. Some participants express uncertainty about their calculations and seek clarification on the relationships between the forces.
Participants are working under the constraints of a homework problem, which may limit the information available and the methods they can use. There is an ongoing exploration of assumptions related to the angles and the forces involved.
saturn67
1200kg car is held in place by a light cable on a very smooth (frictionless) ramp, as shown in the figure View Figure . The cable makes an angle of 31.0 dgree
above the surface of the ramp,
and the ramp itself rises at 25 degree above the horizontal.
how to find tension of the cable and How hard does the surface of the ramp push on the car?
please help
Divide the forces into components along the ramp, or perpendicular to the ramp...
If the x-axis is along the ramp... y - axis is perpendicular to the ramp... write the equations:
[tex]\Sigma{F_x} = 0[/tex]
[tex]\Sigma{F_y} = 0[/tex]
what angle should i use the 25 degree rite?
Fx=T-11760sin(25)=0
Fy=T-11760cos(25)=0
Fx=T-11760sin(25)=0
Fy=T-11760cos(25)=0
What is the component of T along the ramp and perpendicular to the ramp... remember the cable makes an angle of 31 degrees with the ramp.
Also, don't forget the normal force in the Fy direction.
so Fy for nomal force = 11760cos(25) + 11760cos(31)?
No... just modify these equations that you already have:
Fx=T-11760sin(25)=0
Fy=T-11760cos(25)=0
you need to just change a few things... you need to include normal force as one of the forces in the y-direction... and you also need to change from T to the component of T in the x and y directions...
Fy=T-11760cos(25)+n=0
Tx=11760*cos(31)
Ty=11760*sin(31)
i'm not so sure how to get component for T :(
Tx=11760*cos(31)
Ty=11760*sin(31)
you got it...
Tx=11760*cos(31)
Ty=11760*sin(31)
now use these in your Fy and Fx equations instead of just T. you've inserted the normal force correctly.
ramp push on the car is normal force right? humm i still got the wrong answer
n= -11760sin(31)+11760cos(25)
n=4601.33
n=4601.33
no that's not right... you need to get the equations right first... you're almost there... post the Fx and Fy equation... but remember to use Tx, Ty...
post the equations...
Fx=11760cos(31)-11760sin(25) = 0
Fy=11760sin(31)-11760cos(25)+n = 0
right?
right?
no.
these are the equations you need:
Fx=Tcos(31)-11760sin(25) = 0
Fy=Tsin(31)-11760cos(25)+n = 0
now, you have 2 equations and 2 unknowns (T and n). solve for T and n.
oooo so u don;t need weight for tension in component form
Thank you a lot learning physics :D
I don't understand what you mean...
You got the answers? Cool! Good job!
w=mg
Fx= Tx-w*sin(25)
since you said Tx= T*cos(31)
so T don't has any w in it?
saturn67 said:
w=mg
Fx= Tx-w*sin(25)
Yeah. Tx = Tcos31 and Ty = Tsin31. Were you able to get the answers?
yea
i got right answer
thank you
15K
  • · Replies 18 ·
30K
21K
