How can I create a conformal mapping between a square and triangle?
The discussion revolves around the challenge of creating a conformal mapping between a square and a triangle, specifically mapping the side of the square to a point in the triangle while preserving certain properties of the mapping. The scope includes theoretical considerations of conformal mappings and their properties.
  • One participant expresses uncertainty about how to construct a conformal mapping between a square and a triangle, seeking hints or techniques.
  • Another participant questions the feasibility of such a mapping, arguing that a conformal mapping preserves angles and cannot convert a right angle into a straight angle.
  • A different participant claims to have drawn a convincing picture of the mapping and inquires about known existence proofs for conformal mappings, expressing uncertainty about the assumptions involved.
  • One participant asserts that while a mapping exists, it cannot be a conformal mapping due to the angle preservation requirement.
  • Another participant suggests that typically, the map is only required to be conformal on the interior and bijective on the boundary, noting that the proposed mapping violates this condition.
  • One participant speculates that it may still be possible for the mapping to be bijective and angle-preserving in the interior, referencing a known conformal mapping from a square to a circular sector.
  • Another participant seeks clarification on the meaning of "different" in the context of the mapping, emphasizing that the circular sector example does not solve the original problem.
Participants generally disagree on the possibility of creating a conformal mapping that meets the specified criteria, with some asserting it is impossible while others suggest it may still be achievable under certain conditions.
There are unresolved assumptions regarding the properties required for the mapping, particularly concerning angle preservation and bijectivity on the boundary. The discussion also highlights the complexity of defining conformal mappings in this context.
jostpuur
When trying to solve one problem (my own, not an exercise), I encountered the need for a conformal mapping between a square [0,1]^2 and a triangle (0,0)-(1,1)-(2,0), so that the side (0,0)-(0,1) of the square gets mapped into a point (0,0), and the three other sides become the sides of the triangle.
I have no clue how to construct such mapping, or if there exists general techniques for it or already known solution. I barely now the definition of the conformal mapping. Any hints appreciated, if somebody happens to something about this business.
I don't know anything about this. I wonder though. A conformal mapping is a mapping that conserves angles, while you ask a mapping that bends some angles 90° to 45° (and that maps curve to a point). That's impossible, not?
I succeeded in drawing a picture that looked very convincing. It could be that you just didn't try hard enough when trying to see what kind of mapping it's going to be.
Is there any well known existence proofs for conformal mappings? I think I heard about something like that, but I don't know what are the assumptions in those proofs.
There certainly exist a mapping that will do that but not a "conformal mapping". As eendavid said, conformal mapping preserve angles and so cannot convert a right angle, at a corner of the square into a straight angle in the triangle. A conformal mapping can only change a rectangle into another rectangle.
Typically, one really only asks that the map be conformal on the interior, and bijective on the boundary (but you've also broken that rule).
hmhm.. to me this seems that it could still be bijective and angle preserving in the interior.
Okey, matt was first to mention interior.
The conformal mapping from the interior of a square to a circular sector
[tex] \{(r\cos\theta,\;r\sin\theta)\in\mathbb{R}^2\;|\; 0<r<R\;\textrm{and}\; 0<\theta<\pi/4\}[/tex]
is trivial. Map horizontal lines to the lines [itex]\theta=[/itex] constant, and vertical lines to the arcs r=constant. The mapping I'm trying to find would look a little bit the same, but a little bit different too.
Different in the sense that you specifically say the map is _not_ to be bijective on the boundary, you mean?
I mentioned the circular sector example only to make clear what I'm talking about, since I didn't want to start putting pictures on the internet for such small thing. I didn't try to mean much with it. "Different" meant that the sector example doesn't yet solve the problem.
  • · Replies 80 ·
11K
  • · Replies 0 ·
15K
  • · Replies 40 ·
80K
  • · Replies 21 ·
