Formal Definition of Limits, as x -> infinity
The discussion revolves around the formal definition of limits as x approaches infinity, specifically applying this definition to the function f(x) = (sin 3x) / (x^2 + 4). Participants explore how to prove that the limit is 0 using the formal definition, which involves finding a suitable M in terms of epsilon (e).
  • One participant expresses difficulty in applying the formal definition of limits and seeks clarification on finding M in terms of e.
  • Another participant suggests that since |sin(3x)| is bounded by 1, it suffices to show that 1/(x^2 + 4) < e for sufficiently large x.
  • A participant proposes a method for finding M, stating M(e) = sqrt(1/e - 4) and discusses the implications of this choice.
  • Multiple participants emphasize that M should be dependent on epsilon and that one cannot simply pick a single x to test the limit.
  • One participant provides a simpler example (1/x) to illustrate the process of finding M and manipulating the expression to satisfy the limit condition.
  • Another participant confirms that the manipulation shows that if x > M, then f(x) < e, reinforcing the correctness of their approach.
Participants generally agree on the need for M to be dependent on epsilon and that the limit must hold for all x greater than M. However, there is some uncertainty regarding the specific manipulations and approaches to finding M for the original function, indicating a lack of consensus on the best method.
Some participants mention the need for assumptions about the values of e to avoid imaginary numbers in their calculations. There is also a discussion about the limitations of simply picking a single x value to test the limit.
This discussion may be useful for students or individuals seeking to understand the formal definition of limits in calculus, particularly in the context of limits approaching infinity and the manipulation of functions to satisfy limit conditions.
Was this thread helpful?
  • A bit (go ask some more)
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
kioria
Hi,
I am having difficulties trying to adopt the formal definition of Limits as x -> infinity. I will simply try to explain my problem using an example.
Code:
The Formal Definition of Limits as x -> infinity is as follows:
Limit of f(x) as x -> infinity = L, iff we can find M such that
x > M forces absolute value of f(x) - L < e.
note: e = epsilon, M = a function of epsilon
Question:
Find as x -> infinity, the limit of: and prove using the Formal Definition.
f(x) = (sin 3x) / (x^2 + 4), the answer is 0.
Formal definition requires me to find a general equation M, in terms of e. How can I do that with these type of questions?
Here are some I can't do:
Code:
f(x) = (x + 3) / (x^2 - 3)
So given e>0 you must show [tex]\frac{\sin(x)|}{x^2+4} < e[/tex] for all x sufficiently large. |sin(x)| is bounded above by 1, so it suffices to show that given e>0 [tex]\frac{1}{x^2+4}<e[/tex], try manipulating that expression to get some idea for M. Eg 1/x^6 <e for all x> e^{-1/6}
I have actually done that, but I am just not sure if the way I've done is right. It goes like:
[tex]{sin(3x)} <= 1[/tex]
[tex]\frac{\sin(3x)}{x^2+4} < \frac{1}{x^2+4} < \epsilon[/tex]
[tex]M(\epsilon) = \sqrt{\frac{1}{\epsilon} - 4}[/tex]
[tex]x = \frac{1}{\sqrt{\epsilon}} > M(\epsilon)[/tex]
this works out so that if, I replace the x into the first condition, then it satisfies. And there I have left it as the answer.
Is that the correct approach?
Well, x cannot be fixed by epsilon like that, M is fixed by the epsilon, and then as long as all the steps you've taken are reasonable, then x>M will imply |f(x)-L|<e
The x I meant was the x I've picked to test... Is there a better way to generalise the x I pick to test?
you don't pick an x to test. you pick an M dependent on epsilon, and then it must be true for all x>M that..., you can't just pick one x and hope that the infinitely many other cases are also true.
And.. how would I do that? Can you show me how it is done with the above example? Thank you.
Thanks for your quick replies... really appreciate that.
(It's better than being bored to death by the flat pitch in the test match in the Windies right now)
Let's do the easiest example: 1/x tends to zero as x tends to infinity.
Given e>0 we want 1/x<e, or x>1/e, so observing this we make the claim: let M=1/e
If x>M then 1/x<1/M and by choice 1/M=e, and we have solved the problem.
So we are given e, we manipulate the expression to see what M ought to be like, and then we check that if we assume x>M, that things behave themselves.
A rather, refreshing reply. Thanks for your easy example, and because of that I have much clearer understanding of this formal definition of limits. Now going back to the original example I've posted... I still don't have a clue, any more hints? Sorry to bother you... but I am just not getting at this...
Well, we've done the manipulation so we know that letting M = sqrt(1/e-4) is sensible (and assuming e is small enough so that isnt' imaginary) then
x>M => x^2>M^2 => x^2+4> M^2+4 => (x^2+4)^{-1}< (M^2+4)^{-1} = e
so we've shown x>M implies f(x) <e
Oh my god... thanks very much for taking your time to reply. I have finally understood, and now I can do the questions that follows... Thank you.
Did you say you were watching a cricket match? GO AUSTRALIA!
We (England) have got a chance to be the first team in history to whitewash the Windies in their own backyard. We already matched the feat of winning the first three like Oz did last year. I know, the Poms doing well, I can't believe it either. Don't worry, WI have just reached 300 for 2, sorry, 2 for 300 off 75 overs, so we won't be the ones to make history. Good on ya, (sorry, couldn't resist) for figuring it out.
Yes, I couldn't resist too :biggrin:
Eh, yer just bitter you won't whitewash the series 4-0. :wink:
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 16 ·
