Is \(\psi(x) = \frac{1}{x^{\alpha}}\) in Hilbert Space?
The discussion revolves around the function \(\psi(x) = \frac{1}{x^{\alpha}}\) and its membership in a Hilbert space. Participants are examining the conditions under which this function satisfies the requirements for inclusion in a Hilbert space, particularly focusing on the integral properties of the function.
  • Participants are attempting to determine the values of \(\alpha\) for which the integral of \(\psi^{2}\) converges. Questions have been raised regarding the proper formulation of the problem, including the domain of \(\psi(x)\) and the implications of singularities in the function.
The discussion is ongoing, with participants clarifying the problem statement and exploring the implications of different values of \(\alpha\). Some guidance has been offered regarding the need to specify the domain of the function, and there is recognition of the potential issues related to singularities.
There is mention of the integral being evaluated from negative infinity to infinity, and concerns about the function's behavior at singular points, particularly at \(x = 0\) and as \(x\) approaches infinity.
zhaiyujia
[SOLVED] Hilbert Space
For What Values of [tex]\psi(x)=\frac{1}{x^{\alpha}}[/tex] belong in a Hilbert Sapce?
[tex]\int x^{a}=\frac{1}{a+1} x^{a+1}[/tex]
I tried to use the condition that function in Hilbert space should satisfy:
[tex]\int\psi^{2}=A[/tex] but it seems always infinite exist in x=0 or x=infinite
Why are you writing the integral of x^a, when you want to examine the integral of 1/x^{2a}?
Also, have you written down the question completely? What is the domain on which [itex]\psi(x)[/itex] is defined?
one is alpha and another is a. I just write a integral equation, a = 2*alpha. I think it is not the key point. The question is complete. I asked my professor if there is some constrain of x, she said x can be any value. that is to say the integral will from minus infinite to infinite
Okay, they both looked the same to me.
It can not be. There's at least a couple of missing words. Here's one way to write a somewhat more complete question:
For what values of [itex]\alpha[/itex] does [itex]\psi(x)=1/{x^{\alpha}}[/itex] belong in a Hilbert space?
This needs to be specified in the question. You have not completely specified a function unless you describe its domain.
Thanks, I explained it in the interval of minus infinite to minus zero and zero to infinite. I guess a wave function with singularity is not a good one in physic...
  • · Replies 59 ·
  • · Replies 61 ·
