Work and Energy Question ( by 11 PM tonight if possible please)
The problem involves calculating the work done by a pulling force and the work done by kinetic friction on a refrigerator being moved across a horizontal surface. The scenario includes a force applied at an angle and a coefficient of kinetic friction.
  • Mixed
  • Participants discuss the calculations for work done by friction and question the correctness of the approach. There are inquiries about the use of cosine in the calculations and whether the work done by friction should be considered negative.
Participants are actively engaging with the problem, offering insights into the calculations and clarifying the role of angles in determining work. There is a recognition of the need to differentiate between the angles associated with the applied force and the frictional force.
Some participants express uncertainty about the correctness of their calculations and the assumptions made regarding angles in the context of work done by friction.
kasiu
1. A 2.00 x10^2-N force is pulling an 75.0-kg refrigerator across a horizontal surface. The force acts at an angle of 23.0° above the surface. The coefficient of kinetic friction is 0.200, and the refrigerator moves a distance of 9.00 m. Find (a) the work done by the pulling force, and(b) the work done by the kinetic frictional force.
I need help with part b of this problem
mass: 75 kg
distance: 9 m
Force: 200
theta: 23 degrees
2. Work= Force*distance* Cos(theta)
Friction=mu*Normal Force
3. (mass*9.8)-Tension*Sin(theta)=Normal Force
((mass*9.8)-tension*Sin(theta))*mu=Friction Force
Friction Force*distance=work done by frictional force
(75*9.8) - (200*sin(23)) = Fn
735-78.146= Fn
656.85377 = Fn
so,
656.85377*.2=Friction force
131.371= Friction force
so,
131.371*9=work
1182.337 J = work
I have a few questions:
First, what am I doing wrong?
Is cos(theata) = cos(0) = 1
and
would the final answer for work be negative because this is the work of friction?
Any help would be appreciated greatly!
Thank you ahead of time :)
Kind of a strange question to ask for two reasons.
1. We don't have the correct answer or the solution in front of us, so we can't tell you what's wrong with your solution unless we go through it line by line and happen to find a computational mistake (or a mistake in the physics).
2. You haven't said anything to indicate how it is that you know that something is wrong.
Theta is 23 degrees. You said so yourself. Multiplying the pulling force by cos(theta) gives you the horizontal component of that force (the component that actually does work).
Yes, it would be negative because the direction of the frictional force is *opposite* to the direction of the displacement of the fridge.
Nothing.
and
Yes, the answer should be negative because friction and displacement are in opposite directions. (If you like, you can treat the angle between them as 180 degrees. Cos(180) = -1.)
So, quick question:
in my final formula to find work of the kinetic
would i set it up as
Work = Force*cos(theata)*distance
Work= 131.371*cos(23)*9
or would i use
Work=131.371*cos(0)* 9
because cosine would be 0 degrees on the horizontal?
Oh!
Thank you very much!
The both of you have been very helpful!
Once again,
thank you!
I'm sure you have it now, but just in case:
kasiu said:
So, quick question:
or would i use
You would use theta = 0 (or 180) degrees. 23 degrees is the angle of the applied force, not the friction, so it's not directly relevant for part b.
Yeah, my bad. I didn't realize you were referring to theta for the frictional force, and not for the applied force. Anyway, it looks like Doc Al sorted it out.
  • · Replies 56 ·
