Why is the phase constant negative in part B of this graph?
The discussion revolves around understanding the phase constant in the context of a cosine wave graph. Participants are exploring the implications of the sign of the phase constant in relation to the graph's shift along the x-axis.
  • Participants are questioning why the phase constant is negative in part B, with references to the graph's characteristics and the nature of trigonometric solutions. There is discussion about the implications of positive and negative phase angles on the translation of the cosine curve.
Some participants have provided insights into the relationship between the phase angle and the direction of the graph's shift. There appears to be an ongoing exploration of the reasoning behind the choice of the negative phase constant, with no explicit consensus reached yet.
Participants mention the existence of multiple solutions to trigonometric equations and the need to consider the specific translation required for the cosine curve to match the given graph.
neoking77
all the solution is there, but i just don't understand the answer to part B.
for part B, why is the sign negative?
The graph is a cosine wave shifted to the right by an angle less than 90...
So of your two solutions (+pi/3 -pi/3) for arccos, you need the one with the minus, for a right shift, as opposed to a left shift...
Remember that there are an infinite number of solutions to trigonometric equations, so in your case;
[tex]\cos\phi = \frac{1}{2} \Rightarrow \phi = -\frac{\pi}{3}, \frac{\pi}{3}, \frac{5\pi}{3}...[/tex]
[tex]\phi = \frac{\pi}{3} \pm 2\pi\cdot k \hspace{1cm}; k\in\mathbb{Z}[/tex]
But the thing to remember here is that the phase angle is simply a translation along the x axis. A positive phase angle translates the curve in the negative x direction (to the left) and a negative phase angle translates the curve in the positive x direction (to the right).
Now, in which direction do we need to translate the cosine curve so that is matches yours?
Edit: Several mintues to slow ... :frown:
thanks a lot learningphysics and house md
I have iqbal too =O ubcccc
  • · Replies 0 ·
