Vectors
by Adrianw2
Tags: vectors
Adrianw2
Adrianw2 is offline
#1
Oct10-07, 11:51 AM
P: 14
Let B = 5.00m at 60 degrees. Let C have the same magnitude as A and a direction angle greater than that of A by 25.0 degrees. Let A*B = 30.0 m^2 and B*C = 35.0 m2. Find A.
2. Relevant equations
Pythagoras maybe.
3. The attempt at a solution
Well, if A*B is 30 m^2, and B is 5.00m, then shouldn't A = 6.0 m? However, I don't think it's that easy, so I made the right angle triangle with B (5.0m) as the hypotenuse at 6 meters above the horizontal, and got 4.33m as the opposite and 2.5m as the adjacent. Am I going to be calculating areas of triangles? I'm not really sure where to go from there.
Thanks
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
Hootenanny
Hootenanny is offline
#2
Oct10-07, 12:04 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
I'm assuming the astericks denote the scalar product? I think your going to have to set up a system of simulatenous equations.
Adrianw2
Adrianw2 is offline
#3
Oct10-07, 12:11 PM
P: 14
Yeah, the astericks are actually a dot, so it may have something to do with the dot product where it's AxBx + AyBy or something along those lines.
Hootenanny
#4
Oct10-07, 12:16 PM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,789
Vectors
Quote Quote by Adrianw2 View Post
I suggest you write out two equations using [itex]\theta[/itex] to denote the unknown angle.
Register to reply
Related Discussions
Expressing cartesian unit vectors in terms of spherical unit vectors General Math 9
About polar vectors and pseudo vectors Classical Physics 10
Position Vectors, Velocity Vectors, and Acceleration Vectors Introductory Physics Homework 3
PROOF: Independent vectors and spanning vectors Linear & Abstract Algebra 8
Learning vectors: the dot product of vectors General Math 5
