Max Height to Jump Without Breaking Leg Bones
The discussion revolves around determining the maximum height from which a 75-kg person can jump without risking injury to their lower leg bones. The problem involves concepts from mechanics, specifically relating to forces, energy conservation, and material strength.
  • The original poster seeks assistance in setting up the problem and understanding the relevant equations. Some participants suggest using conservation of energy principles, while others emphasize the importance of calculating breaking stress and force.
The discussion is ongoing, with some participants providing hints about the relationships between force, stress, and height. There is a lack of explicit consensus on the approach, as the original poster expresses uncertainty about the setup and equations needed.
Participants note that the problem assumes no air resistance and specifies the distance the center of mass moves during the fall. Additionally, the breaking strength of bone and its cross-sectional area are provided as key parameters.
ussjt
Could someone help me set up this problem and give some helpful hints.
From what maxium height can a 75-kg person jump without breaking the lower leg bone on either leg? Ignore air resistance and assume the CM of the person moves a distance of .60m from standing to the seated position (that is, in breaking the fall). Assume the breaking strenght (force per unit area) of bone is 170 * 10^6 N/m square, and its smallest crosssectional area is 2.5 * 10^-4 m square.
Have you tried it yet?
Conservation of energy.
[tex]\int{Fds} = mgh[/tex]
no, because I need help with the set up for each section...I have been out for a couple days so I don't fully understand the problem. If I knew the equations for each step, I could take it from there.
I more or less gave it to you already.
You know the breaking stress, and the bone's area. Stress is force divided by area. ->solve for force.
You know the force and the distance that force can act on. You know the mass, you know gravity, solve for height.
16K
  • · Replies 19 ·
  • · Replies 26 ·
9K
