What do we call the work due to the change of velocity?
The original poster is seeking clarification on the terminology used to describe work associated with a change in velocity, specifically questioning whether it should be termed "acceleration work" or "kinetic work." This inquiry arises within the context of a thermodynamics course.
  • Some participants explore the definitions of "acceleration work" and "kinetic work," with one suggesting that "acceleration work" may be more specific. Others question the necessity of a unique term, proposing that it could simply be referred to as work.
The discussion is ongoing, with various interpretations being explored. Some participants agree that there is no universally accepted term for the work associated with accelerated motion, while others suggest that clarity in definitions is essential if a specific term is used.
The original poster mentions that this question was part of a quiz, indicating a potential urgency in understanding the terminology correctly. There is also a note of conflicting information received from instructors, which may contribute to the confusion.
ninaricci
Need Help! urgent
I am taking a thermodynamics course and actually i am facing a problem
what do we call the work due to the change of velocity?
is it acceleration work or kinetic work.
i have contacted two instructures in the college and there answers were opposite to each other ... i need your help to know the right definition
looking forward to hearing from you
best wishes :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
What's wrong with simply calling it work?
Well, a change in velocity is acceleration, so I guess it would be acceleration work. Although it's also kinetic, but kinetic would probably encompass more than just 'accelertation work'...AW is the more specific of the two.
To the best of my knowledge there is no unique term for this concept. If you are referring to it by a special term be sure you define that term at some point. As long as you stay away from terms used for other quantities and your definition is clear you should be fine.
Hi
regarding the question i have posted, actually it was aquestion in one of the quizez i have taken...
I would have to agree with Integral in that there is no specific and unique term associated with work due to accelerated motion. The only exception that may be argued is the work done due to rotational motion. An object moving in a circle at a constant speed is by definition accelerating due to a changing velocity. Such references are sometimes referred to as rotational dynamics.
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 28 ·
