| Thread Closed |
last two digits of 2^999 |
Share Thread | Thread Tools |
| Oct11-07, 04:22 AM | #1 |
I was trying to find last two digits of 2^999
I proceeded like this 2=2 (mod 100) 2^2=2*2=4(mod 100) 2^4=4*4=16 (mod 100) 2^8=16*16=256=56 (mod 100) 2^16=56*56=3136=36 (mod 100) 2^32=36*36=96 = -4 (mod 100) 2^64=-4*-4 =16 (mod 100) 2^128=16*16=56 (mod 100) 2^256=56*56=36 (mod 100) 2^512=36*36=-4 (mod 100) Therefore 2^999= 2^512 * 2^256 * 2^128 * 2^64 * 2^32 * 2^4 *2^2 * 2^1 (mod 100) =-4*36*56*16*-4*16*4*2 (mod 100) = 66060288 =88 (mod 100) Problem is this if reduce 2^999 mod 25 I get 2^1 = 2 mod(25) 2^2 =4 mod(25) 2^4 =16 mod(25) 2^8 =6 mod(25) 2^16 =11 mod(25) 2^32 =21 mod(25) 2^64 =16 mod(25) 2^128 =6 mod(25) 2^256 =11 mod(25) 2^512 =21 mod(25) 2^999 = 21*11*6*16*21*16*4*2 (mod 25)=59609088 If I take remainder of 59609088/100 i get the same result as before. Why does this work?That is I can reduce 2^999 mod 25 and take reminder of last number I obtain divided by 100 Again is there a simpler way of doing it? I cannot use Euler as 2 and 100 are not co prime. |
| Oct11-07, 04:55 AM | #2 |
Recognitions:
It is just a coincidence - you have arbitrarily reduced things mod 25 and 100 when it suits you, and not consistently with regards to choices of remainders. Why did you use 21 and not -4, when you used -4 and not 96? (And if you still don't believe it was fluke, then evaluate 30^1 mod 100 and mod 25 to see you don't get the same things).
Assuming everything is random, there was a one in 4 chance of this happening. 2^999 is 13 mod 25, thus if we pick some thing at random that is 13 mod 25, then there is a 1 in 4 chance it was 88 mod 100. |
| Oct11-07, 05:25 AM | #3 |
Thanks a lot matt
Here's why I tried 25. While I took all the pain to evaluate remainders of powers of 2. A brainier guy suggested this. 2^999 = ((2^10)^99)*(2^9) Now 2^10 =1024 = -1 (mod 25) and 2^9=512=12 (mod 25) 2^299=-1*12=-12=13 (mod 25) Now he suggested this 13 (mod 25) could be any of 13 or 13+25 or 13+50 or 13+75 (mod 100) or any of 13,38,63,88 .(As you have already observed in your post) And since 2^999 is exactly divisible by 4 Only choice could be 88 There is only one problem.How did he arrive at 25???????? That's where I always get stumped. Somebody always has an elegant solution to things I work out the hard way... |
| Oct11-07, 05:49 AM | #4 |
Recognitions:
Well, why not 25?
Have you heard of the chinese remainder theorem? That might tell you what you need to know.... |
| Oct11-07, 06:02 AM | #5 |
| Oct11-07, 06:21 AM | #6 |
It says that I can solve a series of modular equations provided moduli are prime to each other .The solution is unique to LCM of moduli. But how do I arrive at conclusion that 25 is possible candidate?? |
| Oct11-07, 07:09 AM | #7 |
Recognitions:
Let's think about this: the C.R.T. says that if I have X mod A and X mod B, where A and B are coprime, then I can find X mod AB. Now, I don't believe you cannot see how 100, 25 and 4 relate to A, B and AB.
| Oct11-07, 10:05 AM | #8 |
| Oct11-07, 11:34 AM | #9 |
I threw a few numbers out of the calculator, and noticed that 3^20 = 1 (mod 100).
Since 2^10 = 1024 = 2*3 . 3 (mod 100), I found easier to use these two facts to reduce bigger powers to smaller ones. In what follows, every time you see a 2^10, you can replace it by 2^3 . 3; and when you see a 2^30 (or a power of it), it can simply vanish. Starting with 2^1000, you have 2^1000 = (2^3 . 3) ^ 100 = 2^300 . 3^100 = 2^300 (mod 100) 2^300 = (2^3 . 3) ^ 30 = 2^90 . 3^30 = (2^3 . 3) ^ 9 . 3^20 . 3^10 = 2^27 . 3^19 (mod 100) Now 2^27 . 3^19 = 2^7 . (2^3 . 3) ^ 2 . 3^20 / 3 = 2^7 . 2^6 . 3^2 / 3 = 2^13 . 3 (mod 100) So 2^999 = 2^1000 / 2 = 2^12 . 3 = 96 . 3 = 88 (mod 100) |
| Oct22-07, 08:55 AM | #10 |
100 = 4 * 25, gcd(4, 25) = 1, so [tex]\phi(100)=40[/tex] and [tex]4^{40n+k}\equiv4^{k}(mod 100)[/tex].
[tex]2^{999}\equiv2*4^{499}\equiv2*4^{40*12+19}\equiv2*4^{19}\equiv2^{39}\eq uiv2^{10}2^{10}2^{10}2^{9}\equiv24*24*24*12\equiv88(mod 100)[/tex] |
| Oct22-07, 09:20 AM | #11 |
Why [tex]4^{40n+k}\equiv4^{k}(mod\ 100)[/tex]? this question is the same question as why the remainder of [tex]2^{999}[/tex] modulo 100 equals the remainder of [tex]2^{999}[/tex] modulo 25.
let m = pq with gcd(p, q) = 1, then [tex]\phi(m)=\phi(p)*\phi(q)[/tex], let a is divisible by p and not by q, then gcd(a, q) = 1, according to Euler's Formula, we can get [tex]a^{n\phi(m)+k}\equiv a^{n\phi(p)\phi(q)+k}\equiv a^{k}(mod\ q)[/tex], then [tex]a^{n\phi(m)+k}-a^{k}[/tex] is divisible by q, since a is divisible by p, we also have [tex]a^{n\phi(m)+k}-a^{k}[/tex] is divisible by p, since gcd(p, q) = 1, we get [tex]pq|a^{n\phi(m)+k}-a^{k}[/tex], in orther words [tex]a^{n\phi(m)+k}\equiv a^{k}(mod\ m)[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: last two digits of 2^999
| Sum of Digits Always Nine | Linear & Abstract Algebra | 8 | ||
| Sum of digits | Precalculus Mathematics Homework | 6 | ||
| last digits of 3^999 | Linear & Abstract Algebra | 8 | ||
| Pi to 24 digits | General Discussion | 38 | ||
| Digits of Pi | General Math | 7 | ||
