What Makes Water's Physical Properties So Unique Compared to Other Liquids?
  • Context: High School
  • Thread starter Thread starter -RA-
    Physics Water
The discussion centers around the unique physical properties of water compared to other liquids, exploring its characteristics, molecular structure, and implications for life and chemistry. Participants examine various attributes of water, including its behavior in different states, its role as a solvent, and its specific heat capacity.
  • One participant lists several unique attributes of water, including its dynamic equilibrium between states, high electronegativity, expansion upon freezing, and high surface tension.
  • Another participant mentions the large polarizability of the H2O molecule and its tendency to ionize.
  • A participant suggests that the simplicity of water's molecular structure contributes to its uniqueness compared to more complex molecules.
  • There is a discussion about water's hydrogen bonding and its classification as a universal solvent.
  • Participants inquire about the specific heat capacity of water and compare it to ammonia, which is suggested to have the highest specific heat capacity.
  • One participant notes the ability of water to form multiple solid phases, mentioning that there may be 11 or even 14 types of ice, some with unique characteristics.
Participants express various viewpoints regarding the properties of water, with no clear consensus on the uniqueness of its characteristics or the comparison with other substances. Some aspects remain contested, particularly regarding the specific heat capacity and the classification of solid phases of water.
Some claims about the properties of water depend on specific definitions and assumptions, such as the criteria for uniqueness and the classification of solid phases. The discussion does not resolve these complexities.
This discussion may be of interest to those studying chemistry, physics, or environmental science, as well as individuals curious about the unique properties of water and its implications for life and various scientific fields.
-RA-
I was wondering what are the physical properties of water that make it so different from other liquids?
I stand to be corrected on this list, but i think water is unique in the following attributes;
- Water is in dynamic equilibrium between the liquid, gas and solid states at standard temperature and pressure, and is the only substance found naturally on Earth to be so.
- It has the highest natural Electronegativity
- It is the only natural liquid that gains volume when frozen
- It is the only liquid that supports all known life
- It is the strongest natural solvent
- Second highest specific heat capacity of any known chemical compound
- Water has a very high surface tension compared to other liquids
It seems to be a lot of characteristics for something that is, in essence, just one oxygen and two hydrogen atoms. Why is it so unique?
The H20 molecule has a large polarizability,
and also readily ionizes.
I found a link that should help. http://www.ozh2o.com/h2chem.html Enjoy!
:confused:
you mean it is a polar molecular?
The simplicity of the structure is the key to it's uniqueness. Complex molecules (such as the Hydrocarbon family) are more likely to have similar chemical "cousins" because the addition of an atom or bond is less of a perturbation to the original molecule if it is complex, than if it is exceedingly simple.
I'm not a chemist, and there are probably other factors, but the trend that simplicity = uniqueness makes sense in my mind.
Claude.
ice109 said:
:confused:
Yes...
Water is a perfect example of hydrogen bonding too, because almost all the lone pair in each molecule are involved in hydrogen bonding..And maybe because of this unique property, water is known as universal solvent..:wink:
Which is the first ? And what is its heat capacity ?
H20 is a really strange molecule with lots of interesting properties. It is e.g. quite amazing that such a simple structure can form so many different solid phases (I think there were 11 at last count).
If you are really interested I cn recommend the book "H20" by Phillip Ball.
It is pop sci but good pop sci (which is rare).
i think that ammonia is the first, followed by water. specific heat capacity is the amount of heat energy required to increase the temperature of a substance by a certain temperature interval. its basically its ability to absorb heat.
thanx for the info. Wikipedia says there are 14 types, and some of them have some interesting characteristics, Ice X1, is a type of of hexagonal ice and is ferroelectric. Is this another unique property of water, that it can form into many different solid states?
  • · Replies 58 ·
15K
10K
  • · Replies 21 ·
  • · Replies 39 ·
10K
