Solving the Infinite Exponential Equation: Does x Exist?
  • Context: Graduate
  • Thread starter Thread starter Kittel Knight
    Exponential Infinite
The discussion revolves around the equation x^{x^{x^{...}}} = 2 and whether a solution for x exists. Participants explore various approaches to solving this infinite exponential equation, including theoretical implications and potential values for x.
  • One participant suggests that x = sqrt(2) might be a solution but questions its validity based on the behavior of the function as Z increases.
  • Another participant states that x must lie within the interval (e^{-e}, e^{\frac{1}{e}}), referencing Euler's proof regarding limits in this range.
  • A participant reduces the equation to x^k * ln(x) = ln(2) for some k, expressing uncertainty about the correctness of this approach.
  • Multiple participants propose that the equation can be simplified to x^2 = 2, although the reasoning behind this reduction is questioned by another participant.
  • Clarifications are made regarding the manipulation of the equation, particularly how taking x to the power of both sides leads to the conclusion that x^{x^{x...}} = x^2.
There is no consensus on the solution for x, as participants present differing approaches and interpretations of the equation's behavior. Some agree on the simplification to x^2 = 2, while others explore different intervals and conditions.
Participants express uncertainty about the validity of their proposed solutions and the implications of the limits involved. The discussion includes various assumptions about the behavior of the function and the conditions under which x may exist.
Kittel Knight
Consider the equation
[tex]x^{x^{x^{...}}} = 2[/tex]
Does x exist ?
Well, at first, I would say x=sqrt(2) , but is this ok?
In general, x^x^x^... = Z would imply x = Z^(1/Z)
But, if x>1, then x^x^x^... is crescent.
In other words, when "Z" increases, then "x" increases.
However, lim oo Z^(1/Z) = 1
So, if x^x^x^... increases, it means that "x" goes to 1 ?!
Where is the mistake?
x must be between [tex]e^{-e}[/tex] and [tex]e^{\frac{1}{e}}[/tex]. Euler gave a proof showing that it only has a limit in this interval.
I don't know if the answer is right, but it's in the interval... so it's possible.
I reduced it to
so i guess find x and k? like x= 2 and k = 0...
dunno if this right just wondering...
It can be reduced to x^2 = 2 immediately.
could u explain for some reason I am not able to see it?
Thanks!
[tex]x^{x^{x...}}}=x^2=2[/tex]
In case you are wondering, Dragonfall is taking x to the power of each side.
x to the [itex]x^{x^{x...}}}[/itex] is equal to [itex]x^{x^{x...}}}[/itex] since there were an infinite number of "x"s to begin with and according to the equation, that is equal to 2. On the right side, of course, x to the 2 power is x2: 2= x2.
makes sense overlooked the fact that there are infinite number of them..
thanks.
  • · Replies 24 ·
