Help w/ Zwiebach Pg 178 Eq 10.73 & Why "In Momentum Space" is True
  • Thread starter Thread starter ehrenfest
The discussion revolves around understanding equation 10.73 from Zwiebach's text, specifically its derivation and the implications of the phrase "In momentum space, the gauge transformation relates δAμ(p) to the Fourier transform ε(p) of the gauge parameter." The subject area pertains to gauge transformations in the context of quantum field theory and Fourier analysis.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the derivation of equation 10.73 by considering the Fourier transform of both sides of a related equation. There are questions about the treatment of derivatives in the context of Fourier transforms and the independence of momentum variables. Some participants express confusion about the implications of moving derivatives and the assumptions regarding the dependence of four-momentum on spacetime coordinates.
The discussion is active, with participants raising questions and clarifying concepts related to the Fourier transform and gauge transformations. There is an ongoing examination of the mathematical steps involved and the assumptions being made, particularly regarding the independence of variables and the treatment of derivatives. No consensus has been reached, but several productive lines of inquiry are being explored.
Participants note the importance of correctly interpreting the variables involved in the equations, particularly the distinction between functions of momentum and spacetime. There is also mention of potential errors in notation and assumptions that may affect the understanding of the equations being discussed.
ehrenfest
Can someone help me figure out where equation 10.73 comes from and why the sentence
"In momentum space, the gauge transformation relates [tex]\delta A_{\mu}(p)[/tex] to the Fourier transform epsilon(p) of the gauge parameter"
is true?
Take the Fourier transform of both sides of equation (10.68)
is true?
This is just a description, in words, of equation (10.73)
Like this
[tex]\int \frac{1}{2 \pi} \delta A_{\mu} e^{-i p \cdot x} dx = \int \frac{1}{2 \pi} \partial_{\mu}\epsilon e^{-i p \cdot x} dx[/tex]
How does that simplify?
ehrenfest said:
Like this
My bad. I'm not doing so good, my answers to your other question were wrong too. Please review that thread.
What I should have said is display (10.68) as the Fourier transform of the momentum equation. Like this.
[tex]\int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \delta A_{\mu} = \partial_{\mu} \int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \epsilon (p)[/tex]
ehrenfest said:
Like this
Like this:
[tex]\int \frac{1}{2 \pi}~( \delta A_{\mu}(p))~ e^{-i p \cdot x} dp = \int \frac{1}{2 \pi} \partial_{\mu} (\epsilon(p) e^{-i p \cdot x}) dp[/tex]
(The integrals are over the momentum). Now, in the secondterm, you may apply the derivative to the exponential which leads to the desired result.
Are you missing a partial in front of the epsilon?
You mean a partial derivative? Jimmy moved it in front of the integral! (which he can do since the integral is over th emomentum)
Interesting. I didn't realize it but we have been assuming that the four-momentum has no explicit x^mu dependence. Is that safe?
Yes. Here, the momentum is to be seen as a totally independent variable. what we are doing here is simply a Fourier transform. So think of p as being independent. It's in the same spirit as doing Hamiltonian mechanics with the generalized coordinates and momenta being independent.
But wait. Even though the integral is over momentum, jimmy moved the partial derivative in front of a term that does have x^mu dependence i.e. the exponential term? That's like saying
[tex]e^{i p \cdot x} \partial_{\mu} \epsilon (p) = \partial_{\mu} e^{i p \cdot x} \epsilon (p)[/tex]
No. One possible source of confusion here is that there are two different functions with the same name! There is the [itex]\epsilon(x)[/itex] and then there is the [itex]\epsilon(p)[/itex] Those are different functions!
The initial expression was [itex]\partial_\mu \epsilon(x)[/itex]
Then this epsilon(x) is written as the whole integral over momentum of epsilon(p) times the exponential. The derivative is applied on the whole thing and then can be moved inside and be applied to the exponential (it goes right through the epsilon(ep) )
I see. So it should really be
[tex]\int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \delta A_{\mu}(p) = \partial_{\mu} \int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \epsilon (p)[/tex]
where I added a (p) to the delta A.
Also, was I correct to dot p and x in the exponential because I noticed that Zwiebach does not do that and it seems like he should because the vector potential A has four indices which would imply that x and p would also have four indices?
Yes, I left off the (p) in error. You are correct that the dot is missing from the exponent in equation (10.71), but present in (10.21) on page 170. It should always be there, but there is no fear of confusion if it is missing.
So [tex]\int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \delta A_{\mu}(p) = \partial_{\mu} \int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \epsilon (p)[/tex]
[tex]\int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \delta A_{\mu}(p) = {\mu} \int \frac{d^Dp}{(2 \pi)^D} ip_{\mu} e^{i p \cdot x} \epsilon (p)[/tex]
So, it seems like you get equation 10.73 by setting the integrands equal to each other? Is that allowed?
Does [tex]\int_0^{\pi} \sin (x) dx = \int_0^{\pi} 2/\pi dx[/tex] imply that sin(x) = 2/pi ?
EDIT: the mu in front of the last equation is a mistake
In general no, but for Fourier transforms, yes. The operator F that takes a function to its Fourier transform is invertable. Therefor
[itex]F(g) = F(h)[/itex] implies [itex]g = F^{-1}F(g) = F^{-1}F(h) = h[/itex]
In the present case, g is [itex]\delta A_{\mu}(p)[/itex] and h is [itex]ip_{\mu}\epsilon (p)[/itex]
Could you also just say that
[tex]\int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \delta A_{\mu}(p) =\int \frac{d^Dp}{(2 \pi)^D} ip_{\mu} e^{i p \cdot x} \epsilon (p)[/tex]
implies
[tex]\int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \delta A_{\mu}(p) = ip_{\mu} \int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \epsilon (p)[/tex]
implies
[tex]\delta A_{\mu}(p) = ip_{\mu} \epsilon (p)[/tex]
implies [tex]\delta A_{\mu}(x) = ip_{\mu} \epsilon (x)[/tex]
implies
implies
implies
You can't move the p_mu out of the integral since it is what is being integrated over
OK. So like jimmy said we need to take an inverse Fourier transform:
implies
[tex]\int \frac{d^Dx}{(2 \pi)^D} e^{-i p \cdot x} \int \frac{d^Dp}{(2 \pi)^D} e^{i p \cdot x} \delta A_{\mu}(p) =\int \frac{d^Dx}{(2 \pi)^D} e^{-i p \cdot x} \int \frac{d^Dp}{(2 \pi)^D} ip_{\mu} e^{i p \cdot x} \epsilon (p)[/tex]
implies
[tex]\int \int \frac{d^Dx}{(2 \pi)^D} \frac{d^Dp}{(2 \pi)^D}\delta A_{\mu}(p) = \int \int \frac{d^Dx}{(2 \pi)^D} \frac{d^Dp}{(2 \pi)^D} ip_{\mu}<br /> \epsilon (p)[/tex]
and that is supposed to imply that the integrands are equal somehow?
implies
implies
In your first step, when you do the inverse Fourier transform, you must do it with respect to a different momentum, say p'. Then you must use that the integral over x of the product of the two exponentials will give a Dirac delta function [itex]\delta(p - p')[/itex] (you have to watch out for factors of 2 pi and so on). Then you will be left at the end with [itex]\deltaA_\mu(p;) = i p'_\mu \epsilon(p')[/itex]
Ehrenfest, if you look on page 316, there is another discussion of equation (10.68). Here it is labeled (15.41). In this discussion, he adds a new twist, the condition that epsilon vanishes sufficiently rapidly at infinity. With this extra condition, you can get equation (10.73) directly from (10.68) by Fourier transforming both sides. I don't have time to show you how right now, but I think you can do it on your own anyway.
I see. So it is:
[tex]\int \int \frac{d^Dx}{(2 \pi)^D} \frac{d^Dp}{(2 \pi)^D}\delta A_{\mu}(p)\delta)(p'-p) = \int \int \frac{d^Dx}{(2 \pi)^D} \frac{d^Dp}{(2 \pi)^D} ip_{\mu} \epsilon (p) \delta(p'-p)[/tex]
implies
[tex]\int \frac{d^Dx}{(2 \pi)^D} \frac{1}{(2 \pi)^D}\delta A_{\mu}(p')= \int \frac{d^Dx}{(2 \pi)^D} \frac{1}{(2 \pi)^D} ip_{\mu} \epsilon (p')[/tex]
and that gives the result we want.
Was I correct to leave that 1/(2 pi)^D in there when I applied dirac delta to the momentum integral?
ehrenfest said:
I see. So it is:
implies
Not quite.
It's only after you have done the x integration that you have a Dirac delta function . Do you see what I mean? It's the integral [itex]\int dx^D e^{i(p-p')x}[/itex] which is proportional to [itex]\delta(p-p')[/itex] (I don't have the time to check the normalization used by Zwiebach right now).
So once you have the dirac delta, the integral over x is gone completely. Then you use the delta function to do the integral over p. So at the end you have no integrals left at all.
You're right. So it should be:
[tex]\int \frac{d^Dp}{(2 \pi)^D}\delta A_{\mu}(p) \int \frac{d^Dx}{(2 \pi)^D} e^{i (p-p') \cdot x} = \int \frac{d^Dp}{(2 \pi)^D} ip_{\mu} \epsilon (p) \int \frac{d^Dx}{(2 \pi)^D} e^{i (p-p') \cdot x}[/tex]
So, I guess we will assume Zwiebach normalized his Fourier transforms correctly:
[tex]\int \frac{d^Dp}{(2 \pi)^D}\delta A_{\mu}(p) \delta(p-p') = \int \frac{d^Dp}{(2 \pi)^D} ip_{\mu} \epsilon (p) \delta(p-p')[/tex]
implies
[tex]\frac{1}{(2 \pi)^D}\delta A_{\mu}(p') = \frac{1}{(2 \pi)^D} ip_{\mu} \epsilon (p) \delta(p-p')[/tex]
Was I correct to keep the 1/(2 pi)^D in the last step given that we are assuming that Zwiebach normalized his Fourier transforms correctly?
ehrenfest said:
[tex]\frac{1}{(2 \pi)^D}\delta A_{\mu}(p') = \frac{1}{(2\pi)^D}ip_{\mu}\epsilon(p) \delta(p-p')[/tex]
That should read:
[tex]\frac{1}{(2 \pi)^D}\delta A_{\mu}(p') = \frac{1}{(2 \pi)^D}ip_{\mu}\epsilon (p')[/tex]
I think that the factor of 1/2pi is wrong, it was supposed to fall out in one of the integrations. But in this case it is irrelevant since you can cancel it out anyway. You can find a proof that the Fourier transform is invertible in a book on Fourier analysis, or perhaps in a book on mathematical physics. As I recall, the proof is more complicated than the one given here, but I don't remember what the issue is.
I see. Thanks.
  • · Replies 50 ·
