The discussion revolves around whether a wire hanger, shaped into a bowl and spun at high speeds, could hold water or solid objects. Participants explore the implications of centrifugal force, gravity, and the mechanics of rotating systems, considering both theoretical and practical aspects of the scenario.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant argues that the wire hanger cannot hold water, comparing it to a bowl with a hole, suggesting that centrifugal force would cause the water to escape.
- Another participant proposes that the viscosity of water might allow it to stay in place temporarily, depending on the rotational speed and the shape of the wire.
- A different perspective is introduced, questioning whether the wire could hold solid objects like a tennis ball or ping pong ball, citing the balance of forces involved.
- One participant explains that the shape of the wire is crucial, noting that a paraboloid shape could theoretically allow an object to rest on it without friction, but instability could arise from small movements.
- Another participant challenges the idea that a solid object could be held, likening the scenario to a blender and emphasizing the increasing force with higher speeds.
- There is a clarification request regarding whether a response pertains to the general discussion or a specific post, indicating potential misunderstandings about the stability of objects on the rotating wire.
- One participant asserts that the stability of an object on the wire is similar to that of an object on a slanted surface, suggesting theoretical possibilities without visualizing blenders or similar devices.
Participants express multiple competing views on whether the wire hanger can hold water or solid objects, with no consensus reached on the matter. The discussion remains unresolved, with differing interpretations of the mechanics involved.
Participants reference various forces such as centrifugal force, gravity, and friction, but the discussion does not resolve the assumptions about the shapes or conditions required for stability in the rotating frame.
