Impulse/momentum/collision question
  • Thread starter Thread starter dnt
The discussion revolves around a physics problem involving an elastic collision between two balls, specifically a cue ball struck by a cue that then collides with a stationary ball. The problem includes parameters such as masses and impulse but requires participants to derive final velocities using principles of momentum and energy conservation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of momentum and kinetic energy conservation to find final velocities after the collision. There are questions about how to mathematically express the relationship between the velocities of the two balls post-collision, particularly given the initial conditions and the nature of the collision.
Some participants have suggested using conservation of energy alongside momentum to create a system of equations, while others have raised concerns about the complexity of the energy conservation approach. There is an ongoing exploration of the implications of the collision being elastic and how that affects the equations involved.
Participants note that the second ball is initially stationary and question whether the collision can be assumed elastic based on the behavior of the balls post-impact. There is also mention of the need to consider energy loss in real-world scenarios, despite the problem stating it is an elastic collision.
dnt
basically a cue ball is struck by a cue, and that ball travels (without friction) and hits another ball (which isn't moving initally). they give all the masses and the impulse of the cue hitting the first ball. they tell us its an elastic collision.
p=mv
I=change in momentum
ok its easy to get the initial speed of the first ball using the impulse/momentum equation. and i know since its frictionless the ball doesn't change speed.
so basically a ball hits a 2nd ball (both have the same mass)...how do you mathematically find the final speed? i know the 2nd ball will have the same velocity as the first one but how do you show it in equations?
momentum: (initials) m1v1 + m2v2 = (finals) m1v1 + m2v2
the first v2 is 0 (2nd ball isn't moving) and all the masses cancel but you only get:
v1i = v1f + v2f
if you use conservation of kinetic energy you get basically the same thing (only the v's are squared).
what do you do with that since the only thing we know (out of 3 variables) is the initial velocity of the first ball?
(also couldn't we assume it was elastic since the two balls didnt stick together?)
anyone?
p=mv
v1i = v1f + v2f
when the 2 balls don't stick, the collision could be elastic or inelastic, depending on whether any energy is lost during the collision. In a perfectly (ideal) elastic collision, such as is given in this problem, energy is conserved as well as momentum. Conservation of energy gives you a second equation, which will allow you (with some difficulty) to solve the 2 unknowns v1f and v2f.
conservation of energy may be quite bothering. You can use another method. Since collision is elastic, the bodies have the same speed of separating as that of approaching.see http://en.wikipedia.org/wiki/Coefficient_of_restitution
this means,
v2(f)-v1(f) = v1(i)
now you have two equations in two variables. solve them
  • · Replies 19 ·
  • · Replies 24 ·
