High Power DAC for SM-10 (0-1000VDC)
  • Thread starter Thread starter Jdo300
    High power Power
The discussion revolves around finding a suitable digital-to-analog converter (DAC) to control the input voltage of a high voltage IC, specifically the SM-10, which generates an output of 0 to 1000VDC from a 0 to 12VDC input. Participants explore various approaches to achieve the required output current and voltage for the application.
  • Jason O seeks a DAC capable of supplying at least 30 mA at 12V to control the SM-10 IC, noting that the maximum input current is 85 mA according to the datasheet.
  • One participant suggests creating an R-2R ladder DAC driven by microcontroller I/O pins, followed by an amplifier to achieve the necessary output voltage.
  • Jason O expresses concerns about using an R-2R ladder due to limited I/O pins and considers using a SPI compatible DAC, specifically the AD7390, while searching for an appropriate op-amp.
  • Another participant mentions the possibility of using an audio amplifier module for post-DAC amplification if the application is audio-related.
  • There is a suggestion to use a regular op-amp with additional BJTs to create a linear amplifier for the output, although specifics on the op-amp's suitability are not provided.
Participants present various approaches and components for achieving the desired output, but no consensus is reached on the best solution or specific components to use. Multiple competing views remain regarding the DAC and amplification methods.
Limitations include the uncertainty about the frequency range of the application and the specific requirements for the op-amp, as well as the constraints of available I/O pins for the DAC implementation.
Jdo300
Hello All,
I have this High voltage IC I purchased from Gamma high voltage here:
http://www.gammahighvoltage.com/html/series_sm.htm
The one I bought, the SM-10, takes a variable input from 0 to 12VDC and generates an output from 0 to 1000VDC.
I want to find the simplest way to digitally control the input voltage so that I can throttle this IC using a microcontroller. The simplest thing I can think of is a DAC, but I don't know if there are any out there that are capable of driving the chip. The datasheet says that the maximum input current is 85 mA but for my application, I measured the input current to be only about 30 mA. Does anyone know if there is a DAC out there that can supply this much output current at 12V?
If not, my other thought was to use a regular DAC with an Op-amp to scale the output voltage and current, but I just thought I would run the question past you all before going that route.
Thanks,
Jason O
Hi Berkeman,
Hmm that's the first time I've heard of an R-2R ladder. Looks pretty useful. That would work quite well for my application but unfortunately, I only have three available IO pins to dedicate to this part of the circuit. I was going to use a SPI compatable DAC so that I can get 10 bits of resolution on the output voltage. I was thinking about using the AD7390 10-bit DAC but I'm still looking around for an op-amp that can source the amount of current I need. So far, I keep finding ones that are either too wimpy or to beefy for my application. The best one I found so far is the LT1206 but I'm not sure if it is okay for it to source a constant current (aparently, it's used as some kind of video amplifier). Would you happen to know of any good op-amps that can do at least 30mA @ 12V? Preferably something that isn't in a metal can would be nice since I don't have much room on the board I'm mounting it on.
Thanks,
Jason O
Sounds like you have the DAC covered. You didn't mention the frequency range of this circuit -- if it's audio, you could just use an audio amp module for the post-DAC amplification. I used to use some audio amp modules (like big ICs with heat sinks) from National Semicondoctor, but I don't have any current part numbers. You could probably find them quickly with a search at National Semi's website.
Alternately, just use a regular opamp, and add some BJTs in as a linear amp at the opamp's output, and close the feedback around the whole shebang.
  • · Replies 38 ·
  • · Replies 36 ·
  • · Replies 47 ·
  • · Replies 20 ·
