Integral of z^n on a closed contour
  • Thread starter Thread starter futurebird
    Closed Integral
The discussion revolves around evaluating the integral of the function \( z^n \) over a closed contour, specifically addressing the cases when \( n \) is equal to -1 and when it is not. Participants are exploring the implications of the variable change and the behavior of the integral under different conditions.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the validity of the original poster's steps in the integration process, particularly questioning the handling of the antiderivative and the evaluation of the exponential terms at the limits of integration. There is also a focus on the implications of the condition \( n + 1 \neq 0 \) and its effect on the integral's evaluation.
Some participants have pointed out errors in the original poster's calculations and reasoning, while others are clarifying the behavior of the exponential function at specific limits. The conversation is ongoing, with various interpretations being explored regarding the integral's evaluation under different conditions.
There is an emphasis on the conditions under which the integral can be evaluated correctly, particularly the distinction between the cases when \( n = -1 \) and when \( n \neq -1 \). Participants are also examining the implications of the periodic nature of the exponential function in the context of complex integration.
futurebird
I'm trying to show that
[tex]\int_{c}z^{n}dz= \left\{\frac{0, n\neq-1}{2\pi i, n=-1}\right[/tex]
I did a change of variables with [tex]z=e^{i\theta}[/tex] and [tex]dz=ire^{i\theta}d\theta[/tex]:
[tex]=i\int^{2\pi}_{0}r^{n+1}e^{i(n+1)\theta}d\theta[/tex]
[tex]=ir^{n+1}\int^{2\pi}_{0}e^{i(n+1)\theta}d\theta[/tex] Moving the constant out.
[tex]=-(n+1)r^{n+1}\int^{2\pi}_{0}\frac{e^{i(n+1)\theta}d\theta}{i(n+1)}[/tex] Getting ready to integrate.
[tex]=-r^{n+1}(n+1)\left[e^{i(n+1)\theta}\right]^{2\pi}_{0}[/tex]
[tex]=-r^{n+1}(n+1)[/tex]?
This is nothing like the answer... where am I going wrong?
Firstly, your work is only valid when n + 1 is nonzero.
Secondly, your ultimate step doesn't follow from your penultimate step.
Thirdly, you computed the antiderivative wrong when going from your antepenultimate step to your penultimate step.
Okay thanks.
If [itex]n+ 1\ne 0[/itex], what IS [tex]e^{i(n+1)(2\pi)}[/tex] and [tex]e^{i(n+1)(0)}[/tex]?
(It's NOT 1!)
(It's NOT 1!)
Wait why isn't [tex]e^{i(n+1)(0)}=1?[/tex] or are you talking about the whole integral?
[tex]=e^{2\pi i}e^{2\pi in}[/tex]
[tex]=e^{2\pi i}(e^{2\pi i})^n[/tex]
[tex]=(1)(1)^n[/tex]
[tex]=1[/tex]
I thought that I fixed my errors since I had the correct solution after integrating in the right way. Then I looked at what happened when n=-1 and everything seemed fine.
But, if this is wrong, then I'm still missing something.
****Nevermind****** I see what you mean now!
[tex]=\frac{r^{n+1}}{n+1}\int^{2\pi}_{0}i(n+1)e^{i(n+1)\theta}d\theta[/tex] Getting ready to integrate, the right way
[tex]=\frac{r^{n+1}}{n+1}\left[e^{i(n+1)\theta}\right]^{2\pi}_{0}[/tex]
[tex]=\left[e^{i(n+1)2\pi}-e^{0}\right][/tex]
[tex]=0[/tex]
But this whole process only makes sense if [tex]n\neq-1[/tex], so for that case we just plug in -1 for n to:
[tex]i\int^{2\pi}_{0}r^{0}e^{i(0)\theta}d\theta=2\pi i[/tex]
So,
  • · Replies 19 ·
  • · Replies 16 ·
