Differentiating a trig function
The discussion revolves around differentiating the function y = cos²((x² + 2)/(x² - 2)) using the Chain Rule. Participants are exploring the differentiation process and comparing their results with a provided answer from a worksheet.
  • The original poster attempts to differentiate the function and expresses confusion over discrepancies between their result and the expected answer. Other participants suggest using trigonometric identities to simplify the differentiation process.
Participants are actively discussing different approaches to the differentiation, including the use of trigonometric identities. Some guidance has been offered regarding simplification techniques, but there is no explicit consensus on the best method to resolve the original poster's confusion.
One participant notes that certain identities, such as half-angle identities, have not been formally introduced in their coursework, which may limit their ability to apply those techniques in this context.
maphco
Differentiate using the Chain Rule:
[tex]y=\cos^2(\frac{x^2 + 2}{x^2 - 2})[/tex]
[tex]y' = -2\cos(\frac{x^2 + 2}{x^2 - 2})\sin(\frac{x^2 + 2}{x^2 - 2}) [\frac{2x(x^2 - 2) - (x^2 + 2)2x}{(x^2 - 2)^2}][/tex]
[tex]\mbox{derivative of cos is -sin so I brought the negative to the front}[/tex]
[tex]y' = -2\cos(\frac{x^2 + 2}{x^2 - 2})\sin(\frac{x^2 + 2}{x^2 - 2}) [\frac{2x(x^2 - 2 - x^2 - 2)}{(x^2 - 2)^2}][/tex]
[tex]y' = -2\cos(\frac{x^2 + 2}{x^2 - 2})\sin(\frac{x^2 + 2}{x^2 - 2})[\frac{-8x}{(x^2 - 2)^2}][/tex]
[tex]y' = 16x(x^2 - 2)^{-2} \cos(\frac{x^2 + 2}{x^2 - 2})\sin(\frac{x^2 + 2}{x^2 - 2})[/tex]
However the worksheet says the answer is:
[tex]y' = 8x(x^2 - 2)^{-2} \sin(\frac{2x^2 + 4}{x^2 - 2})[/tex]
What the *flat line* did I do wrong? My answer isn't even close.
they simplified using a formula for:
[tex]\sin(\alpha)\cos(\beta)=\frac{1}{2}\sin(\alpha-\beta)+\frac{1}{2}\sin(\alpha+\beta)[/tex]
when you plug in your values for sin(a)cos(b) the first sin cancels out
double angle identity
[tex]2sinxcosx = sin2x[/tex]
Bob, we haven't been shown the half angle identities, which is what I assume that formula is used for. I know those formulae, but can't use them because we haven't been shown them formally :p.
Roco, that is genius! :D
if you find that you're differentiating cosine or sine to the 2nd power, i usually differentiate and simplify using double-angle identity
also, when you have secx to some power, re-write the power and just add tanx at the end.
[tex]\sec^{2}x[/tex]
[tex]\sec^{2}x\tan{x}[/tex]
makes the writing a lil easier
Roco, thanks for the idea on simplifying the 2nd power part.
  • · Replies 40 ·
  • · Replies 18 ·
  • · Replies 105 ·
13K
