In order to find the recoil velocity of a spring
  • Thread starter Thread starter jgibbon2
    Spring Velocity
The recoil velocity of the Polonium-214 (Po-214) nucleus after the emission of an alpha particle can be calculated using conservation of momentum and energy principles. The alpha particle has a mass of 6.65×10−27 kg and kinetic energy of 1.16×10−12 J. The mass of the Po-214 nucleus is 214 amu, equivalent to approximately 3.55×10−25 kg. By applying the formula for recoil velocity, v = - (sqrt(2 * KE / m_alpha) * (m_alpha / m_Po)), the recoil velocity can be determined accurately.
  • Understanding of conservation of momentum and energy principles
  • Familiarity with nuclear decay processes
  • Knowledge of mass-energy equivalence
  • Basic proficiency in algebra and physics equations
  • Study the principles of conservation of momentum in nuclear reactions
  • Learn about the decay processes of radioactive isotopes
  • Explore calculations involving kinetic energy and mass in particle physics
  • Investigate the properties and behavior of alpha particles in nuclear physics
Physics students, nuclear physicists, and anyone interested in understanding the dynamics of radioactive decay and recoil velocities in nuclear reactions.
jgibbon2
The nucleus of Po^214 decays radioactively by emitting an alpha particle (mass 6.65×10−27 kg) with kinetic energy 1.16×10−12 J, as measured in the laboratory reference frame.
a) Assuming that the Po was initially at rest in this frame, find the magnitude of the recoil velocity of the nucleus that remains after the decay.
in order to find the recoil velocity... i have tried v=-(sqrt KE*2m)/m ... is there a known mass for Polonium that you plug into this problem? where am i going wrong?
  • · Replies 16 ·
  • · Replies 18 ·
