Understanding Magnetic Flux and Density: Relationship and Comparison
This discussion clarifies the relationship between magnetic flux and magnetic flux density, emphasizing that while increasing current in a solenoid raises magnetic flux density, it does not increase magnetic flux. Magnetic flux is defined as the total number of magnetic field lines crossing a surface, while magnetic flux density (denoted as B) represents the number of lines per unit area. The conversation also highlights that a more powerful rare Earth magnet will have a greater flux density than a regular magnet of the same size, but the total magnetic flux depends on the specific geometry of the magnetic field.
  • Understanding of magnetic fields and their properties
  • Familiarity with solenoids and their operation
  • Knowledge of magnetic flux and magnetic flux density definitions
  • Basic principles of electromagnetism
  • Study the mathematical formulation of magnetic flux and flux density
  • Explore the effects of solenoid current on magnetic field strength
  • Investigate the properties of rare Earth magnets compared to standard permanent magnets
  • Learn about the applications of magnetic flux in engineering and physics
Students and professionals in physics, electrical engineering, and materials science who are looking to deepen their understanding of magnetic fields and their applications.
Mr_Bojingles
I read somewhere that increasing the current flowing through a solenoid will increase the magnetic flux density but cannot increase the magnetic flux.
From what I gather magnetic flux is the space the magnetic field covers or the range of the magnetic flux lines and flux density is how many flux lines there are within the range of the magnetic field.
If I had a regular permanent magnet and a more powerful rare Earth magnet which was exactly the same size as the regular magnet obviously the Earth magnet would have a greater flux density but would it have a greater magnetic flux? Would its magnetic flux lines reach greater distances than the regular magnet?
Since flux requires a definition of the surface being considered (see below), this is not a complete statement. One example of a more complete statement: the total magnetic flux crossing a plane perpendicular to the solenoid axis and located at the solenoid midpoint is zero. For this geometry the statement is true. It may not hold for other cases.
Not exactly. Magnetic flux density is the number of flux lines, or lines of magnetic force, per unit area. It is denoted by the symbol B, and is also called the magnetic induction, or sometimes, confusingly, magnetic field. Flux, on the other hand, is the total number of lines crossing a given surface, so it is a surface integral of B.
I hope this is clearer from the discussion above.
Theoretically, the field lines can fill all of space, but with vanishing density so the magnetic induction B approaches zero far away. The stronger magnet will produce a stronger induction at the same distance, or the same induction at a greater distance.
  • · Replies 24 ·
  • · Replies 27 ·
  • · Replies 42 ·
