Calculating Power in Linearity Properties with Two Sources
The discussion focuses on calculating the total power delivered to a 100-ohm load resistor by two sources in a linear circuit. Source #1 provides 250mW when Source #2 is off, while Source #2 delivers 4W when Source #1 is off. The total power when both sources are active cannot be simply summed to 4.25W due to the linear properties of the circuit, which require consideration of the interaction between the sources. Understanding the principles of linearity in circuits is essential for accurate power calculations.
  • Understanding of linear circuit theory
  • Familiarity with power calculations in electrical circuits
  • Knowledge of resistor behavior in parallel and series configurations
  • Basic concepts of voltage and current sources
  • Study the superposition theorem in linear circuits
  • Learn about power dissipation in resistors
  • Explore the concept of equivalent resistance in circuits with multiple sources
  • Investigate the effects of source interaction on total power delivery
Electrical engineering students, circuit designers, and anyone involved in analyzing power distribution in linear circuits.
Defcon55
I've been presented with a question, but I am not sure how to approach it:
A linear resistor containing two sources drives a 100ohm load resistor. Source #1 delivers 250mW to the load when source #2 is off.
Source #2 delivers 4W to the load when source #1 is off.
My question is, how would I go about finding the power delivered when both sources are on?
I know that the answer isn't 4.25W, because that would just be the sum of the two powers, and disregarding the resistor.
Thanks for your help.
Thread moved to Homework Help forums.
What is a "linear resistor containing two sources"? I'm not able to picture what you are asking.
The linear part just means basically that it is a simple circuit (has additivity and proportionality)
As for the two sources, it could be a power or voltage source, atleast if my understanding is correct.
