Frictional Force: Calculate on 43 kg Mass Inclined at 19 Degrees
  • Thread starter Thread starter grouchy
    Forces
The problem involves calculating the frictional force acting on a 43 kg mass resting on an incline of 19 degrees, given coefficients of static and kinetic friction. The context includes gravitational acceleration and the need to express the answer in Newtons.
  • Participants discuss breaking the problem into components and applying Newton's laws. Some express confusion about the correct approach and the significance of the friction coefficients. Others question whether the problem is in equilibrium.
The discussion is ongoing, with various interpretations and attempts to clarify the problem setup. Some participants suggest different methods for calculating the frictional force, while others express uncertainty about their answers and the requirements of the homework.
There are indications of confusion regarding the application of friction coefficients and the equilibrium state of the block. Some participants mention the need for multiple attempts to submit answers online, which may affect their approach to the problem.
grouchy
a block is at rest on the incline shown in the figure. the coefficients of static and kinetic friction are s = 0.42 and k = 0.36 respectively. The acceleration of gravity is 9.8 m/s^2. the angle is 19 degrees.
what is the frictional force acting on the 43 kg mass? answer in units of N.
I tried brake it up into components and still got it wrong, really have no idea how to do this problem.
The friction coefficient is denoted by: μ
The Normal force is: N=mgcos(θ)
The frictional force is: μN=μmgcos(θ)
yea, I get 167.3454417 as my answer (dont have to put it into significant figures for the homework) and its wrong...
the angle of inclination is on the left, the object would slide to the left if it wasnt for the friction...if it makes a difference but I also tried to submit my answer as -167.3454417 and that was wrong too...
What is the correct answer?
I don't know the correct answer because I need to submit the homework online and it gives u like 7 chances, it only says if ur right or wrong
Well, if it's looking for an answer in terms of N, and the frictional force is μN, and if μ=0.42, then in terms of N, the answer is 0.42N.
its been a long time since i did these types of problems but i think at rest the frictional force would be F=(mew*mg)-mgsin(theta)
This is a duplicate post. I suggest calculating the value of the component of the gravity force acting down the plane. Then apply Newton 1 for bodies at rest to calculate the friction force. HINT: You won't need to know mu.
so is this problem equilibrium or not?
It is given that the block is at rest; hence, yes, it is in equilibrium.
