Incandescent light clarification
  • Thread starter Chi Meson
  • Tags
    Light
In summary, the blackbody radiation curve is free of material-specific lines because a blackbody is a perfect radiator. Incandescent lights produce light via the vibrational spectra, not via atomic transitions. It is just heat. The charged objects that produce light through incandescence are the lattice's vibrating charges.
Chi Meson
1,895
I understand the basics of blackbody radiation and incandescence in general: as the temperature of objects increases, atomic vibration increases, electrons are knocked-up, then de-exite releasing photons, etc etc.
My question is, why is the blackbody curve completely free of signature spectral lines caused by the elemental make-up of the radiator? Why, for example, does the radiation curve not look like an x-ray emission, with both the bremstralung curve, plus characteristic k-lines?
Science news on Phys.org
Firstly, a blackbody curve is by definition free of material-specific lines. In practice it's probably difficult to produce perfect black body radiation, but (noting it's also sometimes called "cavity radiation") one way is to produce a cavity inside a material (with a large internal surface and a small exterior window), so that the radiation has time to reach an equilibrium before it escapes. At first a material might emit a few wavelengths more strongly, but it will also absorb them more strongly, whereas other wavelengths (having a weaker interaction with the material) are reflected better..
As for incandescent lights, I'm not sure to what extent they do additionally produce characteristic lines in their spectra?
Incandescent lights produce light via the vibrational spectra, not via atomic transitions. It is just heat. Since the metallic crystal has a continuous phonon spectrum (as opposed to a diatomic vibrational spectrum, for example), you get a continuous spectrum of light.
Zz.
Zz.
So it is correct to say incandescence it is due to the "kinetic molecular theory" model of vibrating atoms and molecules, and not at all due to electron transitions within the atoms and molecules?
Kinda. That last part is correct, but not the first part.
Remember that a lattice in a solid does not involve just one or two or three, or even a few atoms/molecules. That's why I mentioned that this "vibration" is different than a molecular vibrational spectrum (which can have discrete lines). The phonon spectrum is the result of the collective vibration of the entire lattice.
I think I've mentioned this before in the FAQ when we were dealing with light transport in solids. When atoms/molecules form a solid, they lose their "individuality", meaning most of the properties of the material are not due to the individual atoms, but rather due to the collective property of ALL the atoms. Nothing much of what we see is due to individual atom interaction. Rather, the collective property has form the solid's new energy bands that result in the well-known conduction and valence bands (for a typical band solid). These are what governs most of the solid's behavior.
Zz.
Well that makes a lot more sense. It also means about 2/3 of the elementary texts are wrong in their explanation of incandescence. But what else is new?
Just to be clear, and to make sure I'm not saying anything outright incorrect to my students: since E-M radiation is created by vibrating/accelerating charges, what could we identify as the charged objects producing light through incandescence?
If you consider the most simplified idea of a lattice as a series of + and - charges alternating with each other, i.e. +...-...+...-... etc... then there is a vibrational mode called the optical mode in which you can have, for example, the stretching and contraction of each individual dipoles, i.e. +..-...+..-...+..-...+..-... etc. You can think of it as a gazillion dipoles doing this contraction and expansion all over the solids, and in many different directions. The amplitude of the oscillation will give you an indication of the intensity of the emitted radiation.
Zz.
I see no reason why my high school students can't understand that.
Why is this kept a secret from elementary textbooks? Rhetorical question, no need to answer. Thanks so much, that clears up an irritation I've had for years.
Now to work on that rash.
What is incandescent light clarification?
Incandescent light clarification is a process used to purify water by exposing it to intense heat from an incandescent light source. This causes impurities to break down and separate from the water, making it safer for consumption.
How does incandescent light clarification work?
The process of incandescent light clarification works by exposing water to temperatures above 212°F (100°C) for an extended period of time. This causes the water to boil, which kills harmful bacteria and pathogens. The intense heat also breaks down impurities, causing them to separate from the water.
What are the benefits of using incandescent light clarification?
There are several benefits of using incandescent light clarification to purify water. One of the main benefits is that it is a chemical-free process, making it safe for consumption. It is also a quick and efficient method, with water being purified in a matter of minutes. Additionally, it is a cost-effective solution compared to other purification methods.
Is incandescent light clarification effective in removing all impurities from water?
While incandescent light clarification is a highly effective method for purifying water, it may not remove all impurities. Some impurities may have a higher boiling point or may not be affected by the intense heat. It is always recommended to use additional methods, such as filtration, to ensure the purity of the water.
Can incandescent light clarification be used for all types of water?
Yes, incandescent light clarification can be used for most types of water, including tap water, well water, and even ocean water. However, it is important to note that water with high levels of turbidity (cloudiness) may require additional filtration or settling before the clarification process to ensure effective purification.
11K
  • Quantum Physics
  • Quantum Physics
