How Does the Sagnac Effect Cause Interference Patterns in a Rotating System?
  • Thread starter Thread starter n0_3sc
    sagnac
The Sagnac Effect demonstrates that in a rotating system, two beams of light traveling in opposite directions within a ring cavity create an interference pattern due to differing path lengths. When the entire cavity rotates, the beam traveling in the direction of rotation experiences a longer path than the beam traveling against it. This phenomenon is observable even without relativistic considerations, as it parallels the Michelson-Morley experiment's intentions. Understanding the implications of the source's motion relative to the rotating setup is crucial for a comprehensive grasp of the effect.
  • Understanding of the Sagnac Effect
  • Familiarity with interference patterns in optics
  • Basic knowledge of light propagation and wave behavior
  • Concept of angular velocity in rotating systems
  • Research the mathematical formulation of the Sagnac Effect
  • Explore the Michelson-Morley experiment and its significance in physics
  • Study the principles of light interference and beam splitting
  • Investigate applications of the Sagnac Effect in modern technology, such as fiber optic gyroscopes
Physicists, optical engineers, and students studying wave mechanics and relativity will benefit from this discussion, particularly those interested in the implications of the Sagnac Effect in rotating systems.
n0_3sc
I'm having trouble understanding the Sagnac Effect.
So far all I know is that a ring cavity is formed where 2 beams travel in opposite directions. My question is:
Why do the 2 beams form an interference pattern if the entire cavity is rotating at some angular velocity?
This is easier to see when you have an external light source, in which case, even thinking non-relativistically, you can see that the beams traveling in opposite directions travel through different path lengths before meeting at the detector. (This is similar to what Michelson and Morley were hoping to see).
For the case where the source is also part of the rotating setup, this requires a more careful explanation. It might be better to just refer you to a good source. I can't think of one at the moment, but I will, in a bit.
if you had an external light source, is this rotating as well? if not wouldn't that mean that all the mirrors in the cavity would have to be beam splitters?
Thanks for the help.
10K
  • · Replies 58 ·
12K
