Thread Closed
Please help - Rotational Kinetic Energy of Moving Wheel
Share Thread Thread Tools
Oct18-07, 09:14 PM   #1
A bicycle has wheels of radius 0.3 m. Each wheel has a rotational inertia of 0.08 kg* m2 about its axle. The total mass of the bicycle including the wheels and the rider is 74 kg. When coasting at constant speed, what fraction of the total kinetic energy of the bicycle (including rider) is the rotational kinetic energy of the wheels?
2. Relevant equations
K=1/2 I w^2
I = m r^2 <--- (for a hoop)
3. The attempt at a solution
I don't even know where to start...
Should I use the radius and the mass for the Inertia equation? Should I divide the mass by two since there are two wheels??
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct18-07, 09:21 PM   #2
Total KE in this case is 2KEr + KEt, where KEr is rotational kinetic energy and KEt is translational/linear kinetic energy. Because the bike itself as a whole is moving linearly, it has KEt. And since there are two wheels, there is KEr - but 2KEr because of the two wheels.
So the total ikinetic energy is 2KEr + KEt and the rotational kinetic energy of the wheels is 2KEr. I'm sure you know where to go from there. Good luck!
Oct18-07, 09:51 PM   #3
okay...i got it wrong.
here's what i did:
(2)(1/2 I w^2) + (1/2 m v^2)
that's the 2KEr + KEt
i made up a theoretical velocity (5) since they didn't give me one...and found w using that velocity and the radius of the wheels
so...
(.08)(16.667^2) + (1/2)(74)(5^2)
then took (.08)(16.667^2) over the total...which is wrong. what step do i need to correct?
Oct18-07, 10:13 PM   #4
i would really appreciate it if anyone has any help...
Oct18-07, 10:18 PM   #5
First of all, you dont need to make a theoretical velocity because they cancel out in the end. Now...
(2)(1/2) is 1. You know that w=v/r, so plug in v/r for w, and you get
I(v/r)^2 + (1/2 m v^2)
You know I, r, and m, so you get
((.08)V^2)/.3 + (1/2)(74)V^2
Do you see where im going with this?
TOTAL = (4/15)v^2 + (37)V^2
2KEr = (4/15)v^2
I cant tell you the whole solution because its against the rules. Hopefully you'll be able to figure it out. Good luck!
Oct18-07, 10:37 PM   #6
taking (4/15)/((4/15)+37) gives me an incorrect answer...
Thread Closed
Thread Tools
Similar Threads for: Please help - Rotational Kinetic Energy of Moving Wheel
Thread Forum Replies
Kinetic energy of a moving rotating rigid body Classical Physics 10
rotational kinetic energy Introductory Physics Homework 1
Rotational Kinetic Energy Introductory Physics Homework 5
Calculate the rotational inertia of a wheel that has a kinetic energy of 20300 J when Introductory Physics Homework 1
kinetic energy of a rotating wheel? Introductory Physics Homework 4
