Solve Diode Circuit Problem: Homework Equations & Attempt at Solution
The discussion focuses on solving a diode circuit problem involving two diodes, D1 and D2, with a voltage drop of 0.7V across each diode. The initial assumption was that both diodes were "on," leading to a calculated current of -0.57mA, indicating an incorrect assumption. Upon reevaluating, the user assumed D2 was "off," resulting in a current of 0.43mA and questioning the voltage across the circuit. The conversation emphasizes the importance of validating assumptions in circuit analysis.
  • Understanding of diode characteristics, specifically the 0.7V forward voltage drop.
  • Knowledge of Ohm's Law and its application in circuit analysis.
  • Familiarity with Kirchhoff's Voltage Law (KVL) for analyzing closed loops in circuits.
  • Basic skills in solving simultaneous equations for electrical circuits.
  • Study the impact of diode states (on/off) in series and parallel configurations.
  • Learn about advanced circuit analysis techniques, such as Thevenin's and Norton's theorems.
  • Explore simulation tools like LTspice for visualizing diode behavior in circuits.
  • Investigate the effects of temperature on diode performance and voltage drop.
Electrical engineering students, hobbyists working on circuit design, and professionals analyzing diode circuits in practical applications.
dashkin111
See attachment
We are to assume the voltage drop across diodes is .7v (don't use the diode equation!).
I first was assuming that both diodes were "on". Then my work is as follows:
V1 is the voltage directly above diode D1 (the left most diode)...
[tex]I+ \frac{V_{1}-.7-(-5)}{5k\Omega}=\frac{5-V_{1}}{10k\Omega}[/tex]
[tex]I+ \frac{.7-.7+5}{5k\Omega}=\frac{5-.7}{10k\Omega}[/tex]
[tex]I=-.57mA[/tex]
Now since I is negative, one of my assumptions is wrong? So now I assume the rightmost one is "off" (D2).So.. then
Solving for I
[tex]I = \frac{5-.7}{10k\Omega}[/tex]
[tex]I = .43 mA[/tex]
Solving for V
Well.. since there's no current, v=-5?
Am I approaching this correctly?
So.. then
Solving for I
Solving for V
You're on your way. In this second case, what would be the value of V1? Does this agree with your assumption?
  • · Replies 19 ·
  • · Replies 22 ·
17K
