| Thread Closed |
Resonance and rules for mathematical equations |
Share Thread | Thread Tools |
| Oct20-07, 05:49 PM | #1 |
What is the wavelength of the lowest note that can resonate within an air column 42 cm in length and closed at both ends. 2. Relevant equations Given: l = 42 cm n = 1 Required: [tex]\lambda[/tex] Analysis: l = [tex]\frac{n\lambda}{2}[/tex] therefore [tex]\lambda[/tex] = [tex]\frac{2l}{n}[/tex] I don't know how this came to be, could someone please explain. I've just gone back to high school after 15 years and would appreciate if you could also forward me on to some good links for rules for mathematical equations such as these. Thanks Scott |
| Oct20-07, 08:01 PM | #2 |
Recognitions:
The steps to go from:
[tex]l = \frac{n\lambda}{2}[/tex] to [tex]\lambda = \frac{2l}{n}[/tex] ? start at: [tex]l = \frac{n\lambda}{2}[/tex] first multiply both sides by 2. that gives: [tex]2l = 2\times \frac{n\lambda}{2}[/tex] on the right side, the 2 in the numerator cancels with the 2 in the denominator, so [tex]2l = n\lambda[/tex] Then divide both sides by n. [tex]\frac{2l}{n} = \frac{n\lambda}{n}[/tex] on the right side, the n in the numerator cancels with the n in the denominaotr. so, [tex]\frac{2l}{n} = \lambda[/tex] Then just switch sides. [tex]\lambda = \frac{2l}{n}[/tex] |
| Oct20-07, 09:10 PM | #3 |
Thanks Learningphysics for helping
Scott |
| Oct20-07, 09:30 PM | #4 |
Recognitions:
Resonance and rules for mathematical equationsThis seems to be a complete algebra course online: http://www.themathpage.com/alg/algebra.htm sosmath has quite a few examples: http://www.sosmath.com/algebra/solve/solve0/solve0.html Here's another page where you can practice: http://www.coolmath.com/algebra/alge...e-solving.html Hope this helps. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Resonance and rules for mathematical equations
| [SOLVED] Resonance (Differential Equations Class) | Calculus & Beyond Homework | 5 | ||
| Kirchhoff's Rules and Systems of Equations | Introductory Physics Homework | 1 | ||
| Fundamental rules for physics mathematical derivations.? | Math & Science Software | 10 | ||
| Mathematical rules for Calubi-Yau Shapes | Math & Science Software | 0 | ||
| How Do I Write Out Mathematical Equations? | Math & Science Software | 2 | ||
